bobloadmire
Tgenius, I have no access to an exchange server, and thus no way to test it. While I could probably find someone with one that would let me connect to theirs I doubt I'll be putting much time into this until much later in the cycle, if ever.
Right now my focus is on the GPS; there have been a number of areas of progress but nothing major in the last few days; the biggest change is that the auto backlight parameters are now user-editable under CM7's setitngs screens and thus you can change how you want it to behave (e.g. if you want the buttons on or off for given ambient light levels, etc)
I will probably not push a new version up until I have either GPS or MMS working, although that might change. When something of significance is fixed it'll get uploaded.
I've had no problems with 1x or 3g data at all other than an occasional drop that the base ROM does too, and which appears to be a Sprint thing. If you go into and then back out of airplane mode it clears.
I am running CM7 basically all the time excepting when I need the GPS service and send and receive a LOT of SMS messages. MMS, as noted, is broken though at present.
hey great work. I believe there is a Google exchange server. I used it to sync google apps to my old WM 6.5 device.
