The LED notifications are not working for me - using the 9/10 12:00 noon build. Is there a setting somewhere I am missing?
Everything else is working AWESOME!!!
And now I just got a voicemail and the LED is now working!
still stuck at moto screen.....tried stock recovery and still no luck
Try loading the previous version and downloading the stock nandroid backup from here. You could also do this from a computer and loading it onto you microSD card.i have 4.0.1.4 and still no success how do i truly truly get back to stock i only have the backup of the previous alpha of cm7 that works fine for the most part
I just ran some more tests, my mms works flawlessly on this build as well. Sending and receiving both
hmmm how am i the only person not able to flash this rom!
I still can't flash it either. I've tried 15 or more times with all different combinations of wipes, ect. still with no luck.hmmm how am i the only person not able to flash this rom!
Weird bug, but with the 10AM build, my LED would stay orange when charging and blink green if I had a text. With the Noon build, the blinking still works, but the light is off when it's charging. Seems kinda backwards to me :/
Are you using the stock messaging app or GoSmsPro?
thanks for the step by step SamuraiFox. But I am and have always been on CMW 4.0.1.4 and have done all those steps at least 20 times by now. I am wondering if the PRL is the sticking point. I did the PRL update a while back.Did u use cwm 4.0.1.4
This what you need to do. go and get cmw recovery 4.0.1.4 and the new rom. Install cwm into ur phone by turning off phone and holding down the down volume and power button at same time. Plug phone into PC and open phone. Now open the folder inside. Copy recovery.img to PC for safe reasons. Copy recovery.img from 4.0.1.4. Cwm zip folder to phone And replace original. Now unplug and go to cwm recovery the buttons in this version is different from 4.0.0.9 the select button is menu button and back button is back button. Do a reset data and etc on the first list and go in to mounts and storage and select format system/. After that install zip from SD card and Viola a perfect rom. Oh yeah make sure you backup up your phone or you might be screwed.
