TheBritton
Resident Galaxy Cat
I do not know if this still applies to the newer builds but when I first learned of this issue on the older builds I found out that it only occurs based on the order in which you turn them on. I believe if I recall correctly you could fire up bluetooth while wifi was off and then turn on wifi and all would be fine. However I may be wrong and it might be vice versa. but you'll just have to try for yourself. Hell you might not even get that chance on the newer builds but it's worth a shot if you want em both on.
Thanks! I'll try that. Your answer might explain why sometimes it happens and sometimes it doesn't. I only use them together for Netflix so I've stuck to wired headphone lately. I'll test it out tonight.
