I think this question might have been answered, but ill just go for it.
Does anyone know if the latest Clockwork v5 support ext4?
Just wondering. I tried zdune's cm7 patcher to get a centered clock with no joy. He says maybe cause we're on unofficial ROM. Anybody has a tinker with this? Thanks![]()
I would be interested in that.Figured it out, let me know if anyone wants - has trans not bar mod, too![]()
I had transparency working, but it wasn't quite right when I would pull down the notification bar.
I had enabled it in the framework, and had like 4 themes with it, and they all did that.That would be theme dependent btw - I like to put the notification bar png for pull down status as plain black, do trans or semi-trans on the one visible in the home. Themes will sometimes have that setup up right, or will have the transparent one as the pull down notification bar, too. I am fresh back on CM7 to help a dude out, so I can look into that on a particular theme you want to use![]()
No, no, I'm pretty new to this too lolI had enabled it in the framework, and had like 4 themes with it, and they all did that.
It's probably just me being a noob.
I used out kitchen, and I did the hack I found on XDA forums. Both had the same issue.No, no, I'm pretty new to this too lol
hmmm...what method did you use on your trans mod? I had previously used uot kitchen. Truly, I wasn't on CM7 very long the first time, but I did swap images on a couple of themes to make the backgrounds differ.
But as I was editing code for the clock as well, I hard coded the transparency changeup for this one using apktool. I will look back at my files to see how I changed the pull down bg before...I am on a nearly transparent theme now, and its showing trans for both home and pull down, may need to change the hack...
which xda hack? If it was Taine0's his has been out of date for months due to changes in gb since then. The apktool mods will work. Zdune's patcher will not mod our rom since it's CM7 based and not native. I'd be interested in seeing the link to the one you tried over thereI used out kitchen, and I did the hack I found on XDA forums. Both had the same issue.
I haven't had a BOOT on my phone in, well... you look.
If it's crashing on you it is not the firmware.
Question how can i get the battery icon like you have there? I just finally dove into CM7 and thanks so much for your work Tickerguy its awesome and works fantastic. If anyone could tell me let me know Thanks again!
I also use Go Launcher and haven't had a reboot in a LONG time!I use golauncher and do not have that issue.
3. I saw Minus's Vids (thx by the way) but how do I get the gapps and cm7 onto the phone so I can flash them from CWM? (Maybe include this in vids Minus) I'm just a bit scared messing with my pricey new toy.
4. We need to flash gapps b/c it gives us the market and can't install anything w/o it right? why do we have to flash gtalk? Can't we get it from the market after booting into CM7?
5. Titanium backup: this will let me restore my settings and apps after I move from Stock to CM7? Or do I have to re-download all my apps? Or is there something else?
6. @ Ticker (and other smart ones), are you using anything for protection or to optimize performance...(on the phone I mean) like juicedefender anti virus or anything or is CM7 good to go as is?
HUGE thx @ Ticker, Isaac, Minus n I know I'm missing some but thx everyone. Can't wait! I'm heading to dinner, charging my phone and when I'm back hopefully w/ ya'lls help I can wrap this cm7 install up tonight! Thanks for the hand holding.
