TheBritton
Resident Galaxy Cat
are you still connected to anything else, whether there's an internet connection or not?
it's as simple as that. plug in, enable usb tethering. windows will install rndis and you'll be up automatically. just need to specify your firewall zone.
I don't have my PC connected to any network when I attempt. While the phone is plugged into PC via USB, toggling the Tether option only enables/disables the USB icon in my system tray with the options to "Eject Media". I have USB Storage disabled on the Triumph. It just doesn't seem to be doing anything at all. The Triumph will say tethering has been activated in the notification menu then my PC makes that "USB connect/disconnect sound" and the tray icon for the USB device just disappears. Not sure what I'm doing wrong. Maybe I have to manually install the RNDIS driver?
It sounds easy enough, and it's starting to make me feel dumb lol
