I use Tickerguy's CM7 (v7) and noticed that if I use Titanium Market Tools>Market Doctor>User &, System apps that Titanium shows a bunch of System apps without links to the Market. Apps like Screenshot 1.0.0 and Google Search 1.1.2.
My question is, should I connect these System Apps to the Market or will it screw things up? I would hope that connecting these apps to the Market, it would allow me to know if there is a new version of these system apps available. However I don't know whether these apps are unique because of the CM7 TG ROM. Further I am not even sure that the market updates System Apps.
I have played with this feature before on my user apps and got some unintended results, especially with the apps downloaded from non-market areas like Amazon. Took a while to sort that out, and don't want to have the same issue with the more critical system apps. Thanks for your responding with your experiences.
NO.
Those are internal pieces of CM7. If you connect them to the market they will likely "connect" to the wrong things and will likely break the phone at some point in the future and probably after a fair bit of time when an "update" (which isn't really an update) overwrites something important.
The Screenshot functionality is one of these -- the CM7 code actually calls a binary executable to grab the frame. It literally does nothing other than execute that binary and check the return code! Needless to say all the market "Screenshot" apps do something very different.
Upvote
0
