So my phone went mutant! It had restarted like 6-7 times today alone! I notice my wifi will disconnect even though it says connected (usually fixed by a toggle unless it restarts the phone) 3g seems to require toggles every time after sleep and I get the here now named "black screen of death" about every third time upon wake. If anyone has any fixes I would appreciate it, if not I hope any of this is informative. Thanks tickerguy and Isaac even with small issues your alpha trumps the stock 1000 fold! If anyone found any fixes please let me know![]()
Same Problem.Ran into an issue today using the 9/25 version of the rom with the OC kernel that Isaac posted.
While trying to watch some Youtube videos at work today I noticed that if the phone stays vertical the video will flicker and flash. The sound is fine and the rest of the screen seems unaffected, just the small portion that shows the video flickers approximately 1-2 times a second. Switching to landscape mode corrects the problem until you go back to the vertical position and it starts up again. From what I can tell it doesn't matter if you are on 3G or WiFi, or if you are watching high or low quality video. Youtube seems to be the only thing I can replicate the flicker with, browser flash video and my videos from the SD card seem to work without issue.
I searched the thread for screen flickering issues with video and nothing popped up so hopefully I'm not reporting something that is already known.
I've found that if you disable the wireless once you're done with it, and before you sleep the phone you will avoid all reboots. The reboots seem to be associated with the wireless despite Tickerguy's workaround. From what I've observed quick looks at the phone with wireless enabled are causing the reboots--could be due to the wireless negotiating connectivity in the short window of it being on. Ever since I started turning wifi off before sleep my black screen of deaths and reboots have stopped. (had 7-8 a day prior to this behavior change)
Airplane mode cycling for 3g seems to be necessary about half the time, but really this doesn't seem to be different than stock for me.
Anyone losing 3g and having to toggle airplane mode can go search the Android market for "connection checker" used this on the optimus v when it was having 3g issues. It will detect that you're 3g is down and toggle airplane mode for you
I figured it out! Ran a logcat and found that the Wifi daemon couldn't access the wpa_supplicant.conf or something like that due to a permissions error. I gave that file full permissions and the problem was solved!
Is anyone else having an issue with this latest rom 0.5 taking screenshots. Mine keeps saying:
/mnt/sdcard/tempshot.bmp (no such file or directory)
screenshot saved at null
Ive done a full wipe and still nothing =[
This works great!!! Thanks for the heads up on this! I love the built in log as it's already letting me see some trends on when it's having to toggle the data connection.
Anyone else having problems with the proximity sensor during phone calls? My phone is constantly blinking and occasionally I hang up with my ear. Looked through the settings but didn't see anything that might be causing this. I use launcherpro, don't think that would cause it though
Hey guys,
I'm having problems with the accelerometer with a few games I play. With a free game called Lane Splitter where you move the phone in order to move the character, the accelerometer is unresponsive so it is hard to control the character.
With another free game, Homerun Battle 3D, I can't move around the target when I'm at bat. Is anyone having the same problems? I posted this problem at Github btw. Thanks.
me too.![]()
I installed this last night on the stock build, and MAN it is a battery killer.
