SamuraiFox18
No probs with battery. Played with phone before work and placed in pocket. 8 hours later clocked out and helped boss with his work while listening to music in pocket it said 62% battery life which is sweet.
try lowering the cpu speed and see what happens.Been having terrible battery life the last two days especially today.
Went from Full Charge to 28% in 7 hours @ work. I've checked my programs running. And have had atleast 120mb free in Ram. So programs in the background hasn't been an issue. Will try and run autokiller memory optimization and run it @ extreme to see how well it does there. (I was getting 10+ hours on froyo w/ umph kernal and clocked @ 1.5ghz ondemand from full charge to 50%~ in those 10 hours)
Also I noticed a little bug? Maybe it's just a difference from 2.2 to 2.3. When sending sms' w/ more than 160 characters in froyo would automatically put it to an MMS. While in this mode, it keeps it as an sms but never sends it as a huge SMS. I've found a work around by allowing it to split it every 160 characters and sending multiple sms. But with the MMS, it helps oh so much to get it in one huge text. Just curious is all about that one.
The rom is in prime condition. But the battery life is killing me and is pushing me more and more to go back to stock w/ Umph. Which I really don't want to do.
I have it set to ondemand 122/1024. And I hardly ever turned my screen back on.
Interesting thing I did noticed under battery life consumption. Was phone idle'd and under that it said time without signal 91%. But I was in a position at work where I did have a signal 3-4 bars easy. So... I'm a bit lost.
I noticed you mention "Yahoo! Mail".. after intense investigation I tracked that down to a major cause of my battery shortage. This XDA Forum link explains further: Yahoo Mail causes major battery drain! - xda-developers
Totally agreed, I've seen the Yahoo! mail app suck a handset dry in like 6 hours... there are plenty of good alternatives out there.
People need to remember that battery life isn't totally dependant on the ROM and the kernel it's running under - if you've got a misbehaving or hoggish app hovering in the background eating up CPU it's going to suck that battery PDQ.
With a complete wipe and clean install of 10/16 I am seeing battery life that's just as good if not better than previous builds. I'm wondering if that change to using PWM to 'dim' the soft buttons is maybe saving a teeny bit of juice? Wishful thinking? Maybe but I like it!![]()
i've already got the roboto fonts uploaded onto my phone in the system/fonts folder by extracting them from this link here.... http://api.viglink.com/api/click?format=go&drKey=1154&loc=http%3A%2F%2Fphandroid.com%2F2011%2F10%2F19%2Fdownload-android-4-0-ice-cream-sandwich-sdk-system-dump%2F%23disqus_thread&v=1&libid=1318999621243&out=http%3A%2F%2Fevervolv.turnertechrepair.info%2FClark44%2FAndroid4.0-System-Dump.zip&ref=http%3A%2F%2Fphandroid.com%2F&title=Download%3A%20Android%204.0%20Ice%20Cream%20Sandwich%20SDK%20System%20Dump&txt=http%3A%2F%2Fevervolv.turnertechrepa...&jsonp=vglnk_jsonp_13189996492641 , which is the Android 4.0 system dump with all the app apks and such. now if i can just figure out how to utilize them (the fonts) in cm7.Hey any chance we can get the new Roboto font as default in the next build?
Install "Rom Toolbox," free from market. Roboto is an install-able font. Works great. But Helveticka is the best font for Android, IMHO. Try both.
Yea thanks i've been using it for a while. That wasn't my question though.
I have Skype installed on the newest beta release of CM7. Everything works fine as far as front and rear camera that I've noticed. The only issue I am having is while being connected to WiFi and I put the phone up to my ear during a call the screen times out and my WiFi connection reboots due to the screen timeout. I've went thru every setting in my phone to try and change the screen from timing out while in call. Does anyone know a way of stopping the screen from timing out? I would like it to stay on unless I power the screen off. Thanks if anyone can help.
Settings ->display -> screen timeout doesn't fix it?
About the only other thing I can think of is that Skype is.using the proximity sensor and overriding the display timeout setting. In which case you'd have to find a way to tell Skype not to use the sensor ...
I am also having terrible battery life on this build, i hadnt noticed but it is draining a lot faster, i had it fully charged at 3pm and came work and now its at 46% at 8:40 and i only used it to make a few calls.
I'm also having the same issue even with a fresh install. I guess it's back to stock for me.
