I've been lurking on this thread about a month now and decided it was time to give Tickerguy's CM7 a try. I have a bunch of questions which are probably pretty simple.
When I installed it, I first got clockwork 5.0.23 and made a nandroid and titanium backup, I then did a data/factory wipe, wipe cache partition, wipe Dalvik cache, and wipe battery stats. I loaded the the beta ROM and then Gapps on top of it and rebooted. To get my apps and settings on the new load I did a nandroid restore in advanced settings for data only. That seemed to do the trick but it made me nervous because I haven't read anything here where you guys recommend doing that. So I started from scratch with the same steps above and recovered my apps and selected data like my contacts, call log, text messages, etc. with Titanium instead, It took a little longer but I think I have everything in order pretty well now. If you guys have any comments on my process thus far please let me know. I am curious if the nandroid data restore mentioned above is a bad idea or not.
So here is what I've noticed so far, which are mostly small details:
1.) No matter what I do, I can't seem to get my log of previous text messages restored from my stock rom. Not a big deal, just wondering if anyone knows a fix.
2.) In the stock rom, Navigation has a an option right at the top of the start screen entitled "speak destination" which lets you say a business or address which it then finds for you and sets a route for. In the CM7 load for some reason, after downloading it from market, navigation does not have this option, It won't even let me use the mic button on my Swype keyboard when I select "type destination". Does anyone know anything about this?
3.) I went into CPU settings and set the governor to SmartassV2 no problem, but when I try to set "Min CPU frequency" all I get is a pop up box with that title and a cancel button! I can't do any thing except hit cancel. What's up with that? It seems like this mod really sucks some juice without that 122 minimum set in place.
4.) And finally, I am having an intermittent reboot issue sometimes when I go into settings to tweak things. what happens when it does happen is I will hit the settings icon and a blank screen or a frozen starting menu appears and a few seconds later the reboot starts. Anyone have this problem?
Anyway i'm just starting, hands on with this mod so I'm guessing a lot of this is just a lack of knowledge, but I haven't found anything in the thread about this stuff so any advice would appreciated.
Thank you for this great ROM Tickerguy! My qaudrant score hovers around 2400 just like you said!
