frdmspoplr
Tonight when I connected to my PC via bluetooth, it caused wifi to disconnect. In order to get it to reconnect, I had to turn wifi off then back on, sometimes multiple times, but it always ends up disconnecting.
Proximity sensor fix should be in the just-uploaded build. Little verification time on it but it appears to be resolved.
Front camera is not working wiped /system /cache /dalvik cache and /battery. Not data then tried to install the rom. Then I wiped everything and installed the rom again still doesn't work. Then I tried other programs to use the camera with. Nothing I need help.
Tickerguy, Thank you so much for your time and work on this ROM.
If it wasn't for this ROM, I would have returned this phone the first week I purchased it.
As for people posting about random reboots, I have not experienced this.
*knock on wood*
Note that the screen, when it's on, is a MAJOR pig as is Wifi. Wifi in particular is NASTY when actually moving data...
only thing i could guess is that you had a battery stat monitor app of some sort once and the statistics are saved in some sort of file on your sd card which is being read by some program on your phone once your sd card mounts and is giving an undesirable stats change to your phone somewhere somehow. are you using as of now any 3rd party batter widget or app monitor of any sorts?I have an issue that just started when i flashed the Beta. Never had the problem with the Alpha builds.
My phone shuts down between 35-40% and says the battery is dead. i can't restart it. when i plug it in and restart it, as it's loading it shows between 1-5% battery, then when the SD card mounts, it jumps up to 35-40%. but, if i unplug it, it dies before it gets to 35%. i've tried wiping the battery stats, but it didn't seem to make a different. anyone know how i can fix this?
Yes, it does what you think it does; I have not tampered with the stock settings but you might find value in cutting back the output level.Does the tx power setting in the qcom_cfg.ini do what I think it does? I have scaled it back to 5 mw from the stock 30mw and I still connect fine in 90% of situations. If it is indeed controlling the tx power of the chipset I figure that might be worth a little more power savings for most average users.
Maybe your camera is broken? have you tried going back to stock to verify that?
Please define "broken" - what does it do?
I think SamuraiFox is having the same issue as I am. When I try to take a picture with the front camera (landscape and portrait) I get a pop up saying "Activity Camera (in application Camera) is not responding." In stock it works fine. I have had the issue with all of the builds but I figured since it was in alpha-beta release that is was a fix in the process.
My problem is that when switch cameras it just shows a blank image. Black screen. I have no popups.
When I attempt to take a picture I get a pop up saying "Activity Camera (in application Camera) is not responding."
If you read my post I said WHEN I try to take a picture I get a pop up... the same pop up YOU described. Same problem. Only difference is that my preview works and yours seems like it might not.
I have the same problem with the stock (default) camera app, but I use the LGCamera app (from the market) as my default camera app and this problem does not happen when using it.
If you format /system GAPPS will be wiped as it resides in.... /system. In this case you must reload GAPPS.Does this need to be done after every update? I wiped /system and/cache and battery stats. Was the /cache wipe the culprit?
Not a big problem as I already had it on the SD and as soon as I tired to access the market and asked for a new account, I knew I had to re-flash. Just curious![]()
