genital
I know what you meant, but lol!
genital
- When I unlock the screen (I turned off off/on animations due to glitchiness), I will see my normal android desktop and then it goes into the screen lock
Hey guys, any of you experiencing a bug where the icons have to constantly redraw themselves on the desktop whenever you switch to it from an app? Once the icons redraw the desktop runs OK but it happens almost all of the time and the redraw process is slow. I thought that maybe it was GoLauncher but it's also doing it with stock ADW Launcher.
Thanks for any tips.
I too have random reboots from waking as well as the desktop (or whatever app I was using) before the lockscreen comes up.
I also have had issues with people not understanding me, I thought it was virgin's service but on second thought I don't think so.
Is there a known issue with CM7 connecting to hidden SSID networks? I notice it will not connect to a hidden wireless network. I checked the first post and also the github and nothing is listed. I found some info over at XDA that said it's a known issue. Just checking.
It's not any Gapps, its like GPX fix, fourquare, easyprofiles, etc
can anyone explain this wifi lock thing to me more? I've noticed since I updated to beta4 that my wifi no longer shuts off when the screen is off as its supposed to with juice defender but it no longer does. Won't this drain my battery faster?
Is haptic feedback going to be fixed? Should vibration on notifications be working? The progress is amazing, but I always have my phone on vibrate only but I can't do that now, so I end up missing any notifications.
I'm also getting the dialer drain on beta3. 49% drain is dialer, 49% is Android system, and 3% is phone idle.
