jeckel7234
Have you tried doing a full /data /cache /dalvik wipe?
not for this update, ill def give it a try though
Very stupid question that I would not embarrass myself with if I had not been looking for over an hour. Anyhow the question is how do I format /systemwhen upgrading. I looked around in clockwork for this option but did not see it. Also, if coming from a previous version could I Clear all caches and data ("factory reset") and then advanced restore data to get all my apps and settings back? Please be gentle.
Draining almost double as fast as Stock for me
Just a note on SD cards, there a lot of spoofed (I guess you would call it) cards out there that less reputable sellers (read eBay!) hack to fool your computer/phone into thinking they are whatever size - 32GB like yours was - and are actually a lot smaller. I got burned once - a "16 GB" card would only hold 1GB!![]()
I don't know if this has anything to do with it or if this means anything, but I tried flashing the rom with adb. First, I typed adb shell and got the little $. So I typed su and I got the little #. Any command I typed after that no matter what it was it told me "not found." Not sure what is going on here.
Again, the original problem was that I get this message any time I try to flash any version of the rom in clockwork recovery:
Finding update package...
Opening update package...
E:Can't open /sdcard/update-cm-7.1.0-TG-0.3-Beta-Triumph-signed.zip
(bad)
Installation aborted.
Just curious as to why superuser says that it's due for an update in the Market, yet when I go to manually update it, it just loads forever until it goes back to the superuser page where it asks me to either open or update superuser. Just curious no worry or rush because superuser works perfectly for me as it is.
Is anybody having battery issues with beta 4?
Ok, have what may or may not be another dumb ars noob question. This morning I updated from 3 to 4 without formatting /system and everything worked out great. Later on I decided to do it over with formatting /system just to be safe. After doing this I no longer had a registered Google account and when attempting to set one up again it was no longer an option in account / sync settings. I realized the account was no longer present when I opened the market and was asked if I would like to register an account. After choosing yes it just takes me back to my home screen. Am I missing something? About to try and flash gapps and see if that helps but figured either way I would throw this out there in case anyone else is having the same issue. Again, please be genital as I am very sensitive.
Hi there. I'm enjoying CM7 and have been for the past week, coming from a stock rom.
Some of the few things I've noticed:
- Random reboots from waking (hopefully fixed in beta 4, trying it out now)
- My Android subsonic application will sound glitch randomly while streaming from my home server (not a bandwidth issue). It sounds like a very, very fast sound skip for about a half second every now and again. The best way to describe it is sound glitching. I've not yet tried any other streaming apps.
- WiFi no longer picks up hidden WiFi APs. My work's AP is hidden though it does reveal itself once every x minutes. Unfortunately, with CM7, I am unable to connect to it. This was not an issue with the stock ROM.
- When I unlock the screen (I turned off off/on animations due to glitchiness), I will see my normal android desktop and then it goes into the screen lock
- It is very difficult for people to understand what I'm saying on the phone. This was not an issue with the stock application and is a constant in CM7
- LauncherPro crashes the first time I boot the phone. The behavior is that the phone finishes booting. I will hit the application tray shortcut. Nothing will happen for a while. I will then get the choice whether to wait or kill. If i wait, nothing happens. Sometimes it will FC when waiting. Afterwards it does not FC.
- Dialer application takes a while to come up. This used to not be an issue.
when you format system it delets all google apps, or "gapps" so reflash the gapps package and you should be fine!this happened because all apps are located in /system/app
Dh: Yes. See the release notes. I have been running the last two days with Wifi enabled both plugged and unplugged - no lockups.
