tickerguy
I do not know what juice defender does (or how) but if you have the Wifi policy set to "never when plugged in" or "when screen is off" once the phone is sleeping, off charge, and a few minutes of no data transport go by it will drop the Wifi. By the same token if you say "never sleep" then it will never sleep the Wifi.I thought juice defender was working for me again, but it doesn't seem to be after all. If it is on 3g it seems to work properly, but if the wifi is on it doesn't go off when the screen is off as it should.
Check your policy settings - it definitely works, I've tested this extensively.
As I said in a good signal area 3g is preferable in terms of power budget. In a marginal (or crappy) signal area wifi is preferable. The key is to avoid searching - if either of the radios do that power consumption will go through the roof.
