Battery Monitor Widget. You have to tell it to use "estimated" though as despite multiple requests to the author he hasn't included the Triumph in the XML file (grrr.)
Is anyone else having issues with Twitter and Facebook accounts disappearing. The app remains but when I restart the app it makes me log back in. This issue was non existant in the stock ROM.
Any hints would be apprecaited.
If your call exceeds the timeout setting and you don't touch the phone for that time this is expected behavior. It should go back to the lockscreen since the user interface timed out!The most annoying thing I'm experiencing now (I admit its minor... Shows how good the current build is) is say I'm reading email, this forum, whatever, phone unlocked, and a call comes in, 20 seconds, or 20 minutes... When I hang up, it goes back to lockscreen almost every time (90% or more). Can't narrow down a pattern yet.
if you want to keep track of your battery drain problems and see how many Ma's you're using at all times and log how the Ma's are being generated by which programs search the marketplace for an app called "CurrentWidget" one word. [snip]
Any idea why my phone would (soft) reboot when I try to connect to USB (Computer)
You may have some sort of compatibility problem with things in the /data partition or similar - I don't have problems with both being on at the same time. Just for grins and giggles I powered up the GPS Stauts app while my Wifi was up sitting here and it came up and worked fine.
Note that Maps will by default use whatever it has, and if you're on Wifi it will first try to get a fix off the Wifi. In my case apparently Google knows that my Wifi network is actually mine ;-)
The GPS icon flashes while it is looking for a lock, and once it gets one it will use that.
My guess is that your wifi connection is "unknown" to the Googleplex and as such the initial map location is too when Wifi is running.
Tickerguy, is it possible to dual-boot ROMs? Being able to switch between MIUI and CM7 would be amazing!
