I just noticed another weird issue. Since I use GV for texting, when the phone receives a GV notification while its in sleep mode, the notification gets "disrupted" and not show up in the notification bar, nor does the LED notification works...
It works as it should when the screen is on(notification bar icon, and blinking LED when turned off). Gmail & gtalk also works fine. Anyone else has this problem? any ideas for a fix?
I just noticed another weird issue. Since I use GV for texting, when the phone receives a GV notification while its in sleep mode, the notification gets "disrupted". The notification sounds will ends prematurely if it's longer than ~2 seconds, the LED will blink once then stop blinking, and then when I turn on the screen, there is no GV notification in the notification bar.
It works as it should when the screen is on though(sound, notification bar icon, and blinking LED when turned off). Gmail & Gtalk also works fine in both on/sleep states.
Could anyone else check if they have the same problem? and any ideas for a fix?
Are you sure you flashed the GAPPS.zip as well?Wifi and 3G both not working with beta 0.6. Can't add my account, my phone is totally screwed? Wtf happened...
Is anybody having issues with widgets in status bar on beta 5?
My phone is doing that as well in Beta 6. I am unsure as to why. I suppose I will just flash it again and see if that does the trick.
Front camera does not mirror snapshots or videos taken. Preview, however, is mirrored.
I wiped my system and reinstalled but sadly it did not work...a tad disappointing. Another possibility is a factory reset then installing the ROM. I will just stick with the problem for now and change my sound via the volume rocker. I wonder what could be causing this?Tell me if that works please, thanks!
TickerGuy, I noticed that you haven't responded to any queries about CM7 not being able to attach to hidden SSIDs. This might be an issue upstream with CM7, but I'd like to know if this is on your radar currently or not?
Am I the only one who's phone decidedly (incorrectly) that daylight savings ended today and is now showing the wrong time (off an hour)?
Also for some reason I cant manually set the time to fix this...
I tried toggling the date/time automatic set checkbox, that didn't fix it. Is this an issue with TZ data on the phone... or an issue with the local tower giving wrong time?
Update: ok I can manually set the time but *only* immediately after letting the screen timeout.
Update 2: must have been the tower's fault, because this afternoon it suddenly fixed itself.
For example I touch the brightness icon in the status bar and it goes really bright and I touch the icon again and it wont go back down . Another example would be the sound one as well I press it and goes up in volume but I touch it again it wont change back to either silent or vibrate.
hey android 2.3.7! cool!i doubt that means anything but its still better than 2.3.5....
Go to the CyanogenMod settings/interface/notification power widget/widget buttons/brightness modes and check off the options that you want the brightness widget to go to
