tickerguy
It is entirely unreasonable to expect me to support third-party applications of this sort and reporting it as "broken" when you lead me and others to believe it's the stock app that isn't working is not helpful.I try to send a picture, and it just sits at sending, this is with GOSMS, I tried it with the stock app, and it went fine.
The stock SMS/MMS app works fine and has for quite some time going back to the early Alpha releases. Third party applications may or may not work, and I have no idea what they're doing. Be aware that Virgin does some odd things with their MMS implementation and there were a significant number of changes required to get it to work - a third-party app that is not aware of these won't work - period.
MMS works fine if Wifi is turned on - it will hit the 3g connection to download or upload the MMS. I use this literally daily and have had zero trouble with it since I fixed it back in the early days.
