What do you usually do to repair it? Everything I've tried hasn't worked. I think it's FUBARed.
I'm using a mac so i just used disk utility to repair it.
I just got a triumph rooted and installed cwm. But I see I'm required to install Isaacs version for cm7. But its only an IMG file. So what do I do with that? Never installed or used an img file. Thank you.
I'm using the ice cream sandwich launcher along with the ics cm7 theme and it's awesome! Both can be downloaded from the market..
I just noticed that I cannot send a MMS to Tmobile users, I get a message back from tmobile "The media content was not included due to a picture resolution or message size restriction."
Nevermind, download the zip package and flash it using CWM.
, but a quick google would have solved your problem:Not to sound like a tool, but a quick google would have solved your problem:
How To Install A Custom Recovery To An Android Phone / Device
Just make sure you use the image file in this thread (post #2)!
Being i said i have cwm installed and asked how to install the img file. How about you answer that?
I'm not sure if this is mentioned but I read thru the first page posts of tickerguy and I couldn't find the problem mentioned.
Well my problem is that, ever since I installed beta 0.4, my phone keeps rebooting at random points for some reason. I am certain that some apps are causing this because at the fresh install, it doesn't happen. It runs smoothly. Are there any known apps that could cause this problems? I have tried to factory reset, clean installed the rom by formatting system, data, and cache, but still after installing every apps that I usually use, it starts to become fragile. It wasn't like this on beta v0.3. Now, even after updating to v0.6 beta, it is still happening.
Has anyone encountered this problem? Or is it just me?
I will try to fresh install the beta v0.6. But since I have a lot of apps and customized theme, it's hard..... Lol.
Thanks in advance and thank you and great props to you tickerguy for your awesome work.
If you use Titanium Backup, it saves all your apps and settings. When i used it, it even saved all my texts! You might wanna give it a try![]()
Minor problem but the toggle to put the phone into silent or vibrate mode in the pull down menu isn't working. I keep tapping but it doesn't change. It worked before, anybody having the same problem?
Anyone notice on B0.6 that the backlight acts differently? Instead of brightening slowly, it just flicks from somewhat dim to bright, right away...haven't changed any settings from 0.4 to 0.6, so I'm not really sure why it is different.
Noticed this, too. There appears to be a ticket in the CM7 bug tracker, but it dates back to CM6 (although listed as "new") - seems strange to me that the 2.3.5 build didn't have it.
BTW here's an OBJECTIVE view of battery consumption - mostly idle, except for a few text messages and one ~10 minute phone call today.
7 hours, ~15%, or about 2%/hour. This is with email being pushed to the device on K9mail, using Juice Defender, Wifi off (3g data only.)
The only way you're beating this with a smartphone is if its in airplane mode.
He is right I thought mine was broke too.
in settings after you click widget buttons, scroll down to button modes and the click brightness modes, the put a checkmark in all the %'s you want used. from ipaint66
3G has been working fine in this ROM for quite some time, Virgin Mobile however, has not. I'd say you have a carrier problem, not a ROM problem.I have been using this mod for a little bit now, but I have run into a problem. I have been trying to use IHeartRadio over 3G, and when I wouldn't face an issue before, since I installed this hack, it keeps dropping the signal and I have to continuously stop and start until it works again. Has anyone else been having this issue, or is it just me? I don't think this happens under Wifi - strictly 3G.
