TheBritton
Resident Galaxy Cat
Okay, I just noticed MMS is not sending. Can anyone recommend an app for a temporary fix? Or is everyone else able to send MMS?
Could just be a problem with VM service in your area, it happens all the time.Haven't tried receiving MMS. Just sending.. it sticks on "Sending.." and never sends. People say they never get them. Okay at least I know its working for others. I'll reboot and/or re-flash
Nope like I want it there it just won't work , like okay try it on yours try to go full brightness and click it again see if the brightness goes back down .
For those of you having connection and MMS issues that just sprouted up last night keep in mind that the east coast got blasted with a blizzard-like storm and there are several thousand people without power. This could mean that your service problems have nothing to do with this ROM and there is something wrong with Sprint's network since the storm. From what I can tell if you had service on any of the other ROMs released in this thread there is no reason you should be having issues now as long as it was flashed correctly.
This has been discussed earlier in this thread somewhere. I believe they stated that it is upstream in cm7. Don't count on it being fixed anytime soon.
I know this is a huge thread but this issue has been talked about more than once in it.
I don't mean to speak for him so take this with a grain of salt but he does seem to be merging them at his convenience if I remember correctly. If I'm wrong my apologies to both you and Tickerguy.Yup, just noticed this: https://github.com/ikarosdev/CM7_Triumph_bug_tracker/issues/24
One other question (which, of course may be answered in the thread so..apologies beforehand) but is Tickerguy continually merging upstream changes into this fork of CM7 or are we stuck at a specific revision?
Ticker, just curious, what was the problem with screenshots?
Are you trying to send a picture? or just a long text that is converted into an mms?Haven't tried receiving MMS. Just sending.. it sticks on "Sending.." and never sends. People say they never get them. Okay at least I know its working for others. I'll reboot and/or re-flash
Well yeah I knew that but what caused it not to be able to take a screenshot.The phone wouldn't take a screenshot from the shortcut in the Power Menu.
For me, and many others, we can send pictures just fine, but text MMS does not work. You have to change your settings to split the text message into sms messages.
I try to send a picture, and it just sits at sending, this is with GOSMS, I tried it with the stock app, and it went fine.
Is anyone getting lock ups when your in a call and the other person ends the call on you?
I can't send mms when I have wifi enabled. It sticks at sending.. I need to disable wifi and resend or reboot.Haven't tried receiving MMS. Just sending.. it sticks on "Sending.." and never sends. People say they never get them. Okay at least I know its working for others. I'll reboot and/or re-flash
Same receive problems as you. It gets the mms but can't actually download it. Again, wifi being on is the issue.
When I downloaded the latest version, my micro sd card got corrupted. Now I can't access it, mount it, format it, nothing. Did this happen to anyone else or is it just a coincidence that it happened at that time? It was some no-name brand so that really wouldn't surprise me.
There's a permission missing in the CM7 build tree. It will NOT work on any CM7 build where access to the surface flinger (where it cannot get a direct grab off the framebuffer) is required as it cannot get access to the screen.Ticker, just curious, what was the problem with screenshots?
