blbeach
My Phone has been averaging about two hour from full to 30%
on stock it was around an hour to an hour and fifteen, i...
Sounds like your battery is bad like mine was. Replace the battery and you will get really long run times from this Rom. I had the same issue, the stock battery was bad. Or try an external charger and see if that helps..
(Juiceplotter states I have about 11 hrs left of life, so... 24 hrs standby? Not what I am used to.
) Thanks for every thing Tickerguy! Come Friday you should see a tip with your name on it.
