Are you using both? I think it said in the volime+ description that it could cause conflicts with dsp.Does anyone else noticed a lot of dsp and or volume plus force closes?
I've had it happen once on 1/25 and once on 1/26. But I swiped notifications twice just now, and a couple times in the past couple days, and it didn't occur, so it's obviously very intermittent.
I too like the feature as well, as there are times where I do want to keep a notification up and clear the rest.
As a sidenote, cm7 has had that feature for quite a while, so I'm not sure it could quite be considered "new."
GreyCelt-curious as to your Theme of your MT?![]()
Build 2012-01-26
Updates from Cyanogenmod 7:
- Fixed status bar swipe race (freezing) condition
- Customizable Carrier Label in Settings
- Bluetooth quickconnect option
- ICS rotation & transition animations.
- Option to lock volume keys in silent mode.
- Automatically restart ADB if TCP port settings change.
- Other minor fixes.
Build 2012-01-21:
Kernel changes:
- Touchscreen interrupts have dedicated workqueues now for faster processing. Removed firmware update & other non-functional code.
- Disabled Smartass & SavagedZen CPU governors. They were causing extra early_suspend processing, there are better governors available still.
Other changes:
- Bluetooth & Wifi can be enabled at the same time without 100% CPU utilization.
First version.
I don't use dsp, but I know in volume+ you can disable the settings.Is there a way to turn off dsp manager or volume plus without uninstalling them?
Has anybody sent a notice to CM?
Is it only when you swipe notifications off, or at other times?I saw on github that Whyzor already posted a comment. Its freezing on my build too. I just hate to have to reboot every time it happens. I may revert to one of my older builds until there is a solution.
when I touch the items on the menu it will sometimes freeze, kind like a half pass. I also have wakelock issues. Doesn't happen often either.
But I like that feature :O
At least make it optional?
I'm still using 1\21 build. I hightlighted the CM7 line where there might be a clue.
Edit: My point is that I use the swype to remove notifications sence I discovered it exsisted. I am going to apply the 1\31 kernel now
Any idea what causes the glitchy video in portrait mode? I know it's a known issue but it doesn't just affect video players (ie. youtube, etc.). If it was just a matter of needing to switch to landscape to watch videos, I'd have no problems but this also affects my favorite weather apps, BeWeather and GoWeather! The animated in-app backgrounds apparently use video and it skips and stutters and in general ruins the feel of the app. I love this ROM and really don't want to go back to stock just to use these weather apps...
Wait, I'm a little confused about the 1/31 kernel - Is the intention to fix the wakelock problem, or just make it more obvious to BetteryBatteryStats users?
Is the advised way to maximize battery life still to reboot after deactivating wifi or BT?
Thanks!
