thangfish
Android Expert
I've also made a habit of that, when finished with the camera.Holding down back when exiting the camera or killing in applications seems to do the trick.
I think I can consistently reproduce this problem (using 1-26 build)Phone lasted less than 7 hours again today. Before it died, I checked BBS and sure enough, mmc1,2,3. Threw in the new battery, started up, and no issues again. Cycled wifi a few times and has still been fine. Weird. Past few days have been great though. Just about got me through the day on one battery.![]()
I'm sure it has something to do with whatever fix Whyzor made for the freezing status bar.
1. Have JD enabled, and let it manage Wifi
2. Turn on Wifi, wait till Wifi connection takes over 3G.
3. Turn off screen and wait a minute, let JD to disconnect the Wifi
4. mmc1 2 3 are now showing up and wouldn't go until reboot.
Anyone can reproduce this problem?
Please let me know if there is any test I can help run on the phone
Oh alright. I thought it was a fix you made. I used to run my phone like you as well. Oddly enough, I never had the status bar freeze on me until the 1/25 build, the first to incorporate the upstream cm7 fix, and I've experienced it one other time since flashing 1/26. Also, ever since the 1/25 build, probably 9 times out of 10 I get a status bar fc when I boot. It never occurs prior to 1/25, so I'm assuming its related to the fix, which obviously didn't completely work since I never encountered the problem until the fix lol.The status bar fix was upstream from CM7. I never noticed freezing status bar before, nor after that was in the build. I basically run with all animations, transitions, performance settings set for performance instead of eye candy. Maybe that has something to do with it. I'll keep a lookout for it.
Front & back camera works fine here. You may need to rewipe caches.
The last time I visited this forum there was a new kernel posted: WhyKernel-01-28
I flashed this kernel and since have seen quite a noticeable improvement in battery life, however, it appears that this kernel update has since been removed. Is there a known problem with this kernel WhyKernel-01-28? I haven't noticed any problems so far. In fact, the battery life gain since flashing this kernel has been really great.
I'd like to know how in the heck you guys are getting such great battery life! I'm on the latest build and kernel minus the 1-28 kernel. Right now I'm @ 53% with 4hrs 20min off charger so that will get me 8hrs if I'm lucky.
Thanks Whyzor. Yeah, when I'm at home I have wifi on the whole time. When I'm going out and I'm not going to be near a Hotspot I turn off wifi. I've also gotten in the habit (probably from my days with the Intercept) of turning the wifi sleep mode to never. So, once you get that wake-lock fix out in the next kernel, I can set that to "when screen turns off" and save more battery, right? Maybe that's why I never experienced the wake-lock problem that everyone is talking about because I always had mine set to "never".
No, you won't experience any difference unless you turn off Wifi & BT. TG put an intentional wakelock for wifi (& I did for BT), so it doesn't fall asleep when screen is off and some app needs it (like a VoiP, or transferring data in the background). It's a problem with the proprietary driver on the MT, and we don't have source code for that, so this is just a workaround for it. You would get much better battery by turning OFF wifi & BT when not needed. Even use 3G to sync small amounts of data in the background.
Is that intentional wakelock whats keeping the radio from going into standby? a lower power mode? I see that in the qualcomconfig file that there are three modes. Deepsleep, standby and mcastfilter. I read somewhere that there is a lower power setting that is there for such things such as voip.
What governor are you guys getting one day out of the triumph using? I have my min at 245 and max at 1305 with Smartassv2. Will switching to InteractiveX improve it that much? I can usually get about 16-18 hours on a non school day where I have decent service and am not constantly using wifi.
Why does the headphone media volume sound very low even at the highest volume? Alredy tried different headphones. Also tried same headphones on the Optimus V with Cm7, played the same song and the sound from the OV was much, much louder. Im using PlayerPro on both phones with same equalizer settings. Why does it sound very low on the Triumph?
I'm sorry if this was mentioned before, but does this have the 2 way call recording patch?
There's probably a bug in the code on the MT that makes it low. I've heard others say using an app like DSP Manager or Volume+ can boost it. The couple of times I briefly used the headphones, it sounded fine.
I have a new kernel uploaded, it should fix the wakelock issues, or at least show up as "wlan_lock" or "bt_lock" in betterbatterystats instead of MMC or "event", if it's TG's or my code that's doing it.
WhyKernel-01-31.zip
