Just had the Status Bar freeze up on me. I'm on the 1-25 build with the 1-31 kernel.
I've yet to experience any status bar freezes (I run pretty minimal setup). The upstream CM7 fix for this was commited on 1-22. So has anyone noticed this problem before that date? (before TG-Reloaded 1-25/26 builds). If not, maybe that broke things for our phones & I can try to revert the changes. Basically trying to see if this is a recently new problem or not.
Excuse the n00b question, but do I flash the kernel the same way I flash the ROM?
I only had it happen one other time but I can't remember what build or kernel I was on. I think it was right before I flashed the 1-26 kernel so I would have been on the 1-25 build with the 1-18 kernel...I think. Was there another kernel uploaded in between 1-18 and 1-26? I DO know that it never happened to me when I was on the 1-14 build.
OK...What happens is when you get a notification and swipe down to bring the notification screen down, then swipe the notification itself to the left or right to get rid of it, it freezes half-way through the swipe action and the notification itself is then stuck there. Then the rest of the notification screen freezes and you can't use the Power Widgets or anything else on the notification screen. The only way to get rid of it is to reboot the phone.
See below...the notification that says "ed Threads". It will get stuck just like that and then freeze everything. You can still swipe the screen up or hit the home button to go back to home screen, but if you swipe the notification bar back down, it is still frozen.
Ahh, it's the left/right swipe feature in CM7. I never use that (just hit the clear button). That feature is new & still buggy, will just have to wait for CM7 to update it more. In the meantime, don't use left/right swipes.
BTW This is why detailed problem reports are good. One liners are NOT.
I get the freeze occasionally if my aim is bad when I try to open a notification and accidentally cause it to swipe slightly to one side.
Edit: In fact JUST after typing this tried to open a notification and missed and froze the bar!
I'll see if I can disable that feature in future builds.
There's probably a bug in the code on the MT that makes it low. I've heard others say using an app like DSP Manager or Volume+ can boost it. The couple of times I briefly used the headphones, it sounded fine.
I have a new kernel uploaded, it should fix the wakelock issues, or at least show up as "wlan_lock" or "bt_lock" in betterbatterystats instead of MMC or "event", if it's TG's or my code that's doing it.
WhyKernel-01-31.zip
same here build 1/25>kernal 18 no problemsWell I'm running the 1/25 build with the 1/18 kernel and don't have any status bar freezups.
