Root [ROM] CM7 TG-Reloaded (Final: 03-25)
I noticed this yesterday, but didn't think anything of it, till it happened again today. When you use the camera, and switch to the front camera, the screen goes black, and will not come on, you can even try to re-open the camera app, and it is just black. I reboot, and open the camera app, and now it is on the front camera, and I am able to switch to the back camera with no problems.
Any chance you might fix the proximity sensor in the next build? The phone constantly flashes while in call and on bluetooth the screen stays on while in my pocket.
Edit: Disregard this. The screen staying on during a bluetooth call is by design.
I thought the flashing in-call was fixed a long time ago... TG releases.
Neither of these things affect me on any of the reloaded roms.
Front & back camera works fine here. You may need to rewipe caches.
For anyone having wakelock problems, try flashing this (FILE REMOVED)
Wiped caches, installed kernel and have 0 sleep time after about an hour and a half. Ran nothing after boot up... Just been sitting.
Update:
phone slept fine last night. I haven't used it or done anything.
I'll keep track of it some more.
Yeah, that was my bad. I had "Always use Proximity" unchecked and that was causing the flashing when ever I moved around. Sorry for the confusion.
Is anyone else getting a statusbar crash (ForceClose) at boot-up? systemui crashes then if something puts up a notification it loads and stays running.
I think one of your battery widgets is broken... Also that's been on standyby from the looks of it so not that surprising...
What widget? Also, it has been on, and I was lisening to music for about 2 hrs yesterday, surfing the web for about 30 mins, made 3 phone calls, and check email every 30 mins
The battery icon that says 27 in the status bar when the cm7 one says 17... Unless that's for something else... And wow... I can usually drain my battery pretty fast surfing the web during break at work... Then again that's with hardly any service and brightness all the way up...
That's 17 mins left if I were to continue to use it with that brightness, connection, etc
Code:
the application status bar (process com.android.systemui has stopped unexpectedly)
Yes, here too. CM7 TG-Reloaded (Latest: 01-26)
Have done a "upgrade" 5 times all with the same results
1. Wipe Cache.
2. Wipe Dalvik.
3. flashed the ROM then Gaps repeating steps 1 - 2, then reboot
Re-downloaded the zip just in case it was corrupted 5 times ;)
Did a "clean" install 5 times all with the same results
1.format/system.
2. Wipe data factory reset.
3. Wipe Cache.
4. Wipe Dalvik.
5. flashed the ROM then Gaps repeating steps 3 - 4, then reboot
So far besides the systemui error, everything else works great :D
Good to see that I am not the only one that has the problem. That means I didn't break something with all my messing around.
my phones been off charger for 4 hours and im only at 93% battery! :D great job! lol love it
Just hit 24 hours and have 18%. Also, have had issues with sleep time after using camera since way back. Holding down back when exiting the camera or killing in applications seems to do the trick. Have noticed big drains when still running in background. Also use camera fx zoom so it could be the app. Not sure about stock.
