idbl_fanatic
mine isn't going into Deep Sleep now (newest build)
No problem with that here. Haven't reverted to last kernel yet either... Don't use headphones much.
how do you check to see if it deep sleeps? cause i will see if i have that problem.... (i just flashed with old kernel) and i use headphones all the time so i need the old kernel lol![]()
CPU Spy from the market
Umm...ok...maybe I'm going crazy...I could have sworn there were a bunch of places I wasn't seeing it, but after doing some before/after screenshots I've concluded that apparently I'm off my rocker...lolWhere do you NOT see roboto font? I see it pretty much everywhere, including lockscreen. Only part I don't see is the default alarm clock app, which still uses old DroidSans.
So when we load the new builds don't they bring the new kernels with them or do I have to flash them seperately?
Whyzor, would you be willing to post this to ROM Manager?
- Improved UI response without sacrificing battery or performance by switching to Interactive governor & SIO scheduler as default
Quick question - I see this as one of the updated items:
But on my phone and my wife's phone running 01-25, when I reboot the governor is always set back to ONDEMAND. Shouldn't it default to INTERACTIVE? I do not have the "Set on boot" box checked. Do we need to clear the Cyanogenmod data in applications to reset preferences back to default or something?
I don't see the benefits of using it. The instructions are similar. And if something goes wrong, the user has to learn how to use recovery anyway. Learning how to flash recovery is good knowledge, learning how to use ROM Manager only would be helpful if a device supports it. Just too many hoops to jump through for not a lot of benefits.
BTW, I uploaded 01-26 build with a working headphone kernel (some of my experimental settings broke it apparently). If you are running ROM 01-25 with kernel 01-18, there's no need to upgrade.
Is the any way to get a stock launcher? I'm not a fan of the ADW launcher. I know IHO guys made flashable zip for a stock launcher on the OV . Is it possible for us to get something like that?
Its a great ROM by the way. I'm grateful someone is continuing development for CM7. Just can't stand ADW haha!
there is a flashable zip I found on the cyanogenmod forums that replaces age with the stock gingerbread launcher. You just flash it in recovery and good to go I'm not at my PC right now but I'll link it later unless someone beats me to it.
