CM Settings > Sound > Mute camera shutter
Thank you very much....
thank you! ill go ahead and try this outyes i think headphone jack was brokein that build becuase of kernal.i flash #18 kernal to fix that hope that help
Whyzor, is mantera's kernal updated for the wakelock issue like yours? Just curious, I've been using his for quite a while. I'm going to try yours to see if the issue goes away. Thanks Whyzor.
Hey Wyzor is there any reason this rom would have issues hooping APs? my friend has a Atrix running CM7 and it hops fine, but mine disconnects and reconnects to every AP and won't continue the session.
Whyzor,
Have been on a build from source kick and was wondering if inserting your kernel would be as easy as using 7zip to delete the boot.img from my build and then adding the image from your Rom? Is there anything else that would need to be done or is there a specific process of doing what I just described?
What is hooping APs? I don't have problems connecting to one router at a time.
Hmm, TG's wifi hacks probably doesn't support this mode, stock may be using a different wifi module/driver than CM7. Keep in mind the hardware interaction level is all reverse engineered without documentation.At our work we have a wireless network called "AHPublic" and it has probably 50 Access Points (APs) On most phone when one goes out of range, there is another in range and instead of disconnecting it migrates to the closer AP. The MT with this CM7 build does not, but stock 2.2 did. Is that clear? Thanks for the help!
ok cool, so probably not gonna happen?
Whyzor:
I've figured out what is going on with the wifi wakelocks and JuiceDefender. When the user is managing wi-fi directly, everything works as intended. Turning on wi-fi loads the libra driver and connects as normal. Turning off wi-fi unloads the driver and disconnects, no problem.
Things get more complex when the screen turns on and off. With libra loaded and the screen off, the btwlan_early_suspend() routine runs, creating the wlan_lock wakelock and keeping wifi active as intended.
Upon turning the screen on, the btwlan_late_resume() routine runs, destroying the wlan_lock wakelock. This is all good!
When JD runs, the normal logic breaks down since it operates on the BT and wifi interfaces after the screen has already turned off, bypassing the custom wakelock logic that you've programmed into drivers/power/bq275x0_battery.c
With JD, the libra driver is unloaded maybe 5 seconds after the screen turns off and the interface is determined idle. Since your btwlan_early_suspend() routine has created a wakelock after screen off, it remains there until the screen turns on again, despite whatever JD does to the interface in the meantime.
I'm not an expert C coder, but it looks like the wakelock routines are being event driven. Is that the case? If so, the kernel needs some hook to be informed that the wifi has been deactivated in some alternate way.
[snip]...
I spent some time yesterday updating my Froyo backup in case I need it for HDMI. I was quite shocked by how slow it seems to me now that I have been on CM7 for several months. I am NEVER going back to Froyo daily!
Can you answer a question for me? I'm Visually impaired, and want to know, does CyanogenMod7 offer settings for changin the system wide android font? And if so, how far can it go up in point size? And bold? Yes, I've heard that 2.3 has font size settings in display, but I've seen 2.3 phones and they have no such feature, and it's not in documentation either. I'm a root newbie, and I won't try this stuff if it doesn't help me by giving what I want. I've also been told that Pico TTS will not be affected. Is this true? Thanks in advance, and yes I do think what you do is cool, and want to be a part of it.
First, I wanted to say thank you again to Whyzor who's 2-02 build is awesome. I have the best battery life ever and the phone is so responsive. I am glad I kept it.
Unless another dev steps up and fixes it, no.
If JD can properly disable the wifi module after early_suspend() runs during screen-off, a big *IF*. I guess then there could be a way to tell the kernel that's in deep sleep mode to poll every once in a while to check if wifi is loaded, if it's not, release the wakelock. I'd have to dig around to see if such a function exists & where.
This is all a lot of work just to get an automated way of turning off the wifi with JD (which I don't use). The current manual toggle is very simple already. Not a high priority fix, maybe when I have more time to play with things.
Is there a way to map the recent apps menu to the search key. I can't remember if it's in the CM7 input settings because of the bug in the current build. If its not in there, is there an app that can do it?
I don't think there exists a solution to do it. I personally would like faster access to the recent apps menu instead of the hold-home-key too. Even filed an enhancement tracker for Cyanogenmod, so far not much interest.
Yeah, it's definitely pretty annoying having the hold the home button every time I wanna multitask. Would it be possible to modify the time you need to hold it like you did with the back button? Obviously this could potentially lead to more accidental pushes, which could annoy people, but it's a thought.I don't think there exists a solution to do it. I personally would like faster access to the recent apps menu instead of the hold-home-key too. Even filed an enhancement tracker for Cyanogenmod, so far not much interest.
You learn something new every daydoes that work? I've never known about the long press home key thing. Have to try it. Isn't there an app like a button remapper on the market?
