MRCMidnight
I like to add that this ROM crashes phone on Bouncy Mouse Free game. Every other game works fine.
~ Sent from my Triumph using Tapatalk ~
Same experience here. After updating to the latest build every game works great except one. Asphalt 6 crashing every time I try and play it now.
Edit: Also, my entire phone crashes not just the app. The phone automatically reboots after a sound crackle followed by the screen going black.
Another solid build! Thanks, threw a few more bucks your direction (I keep pointing this out to try to encourage other people to do the same)
Back to back dumb question time,
1, I cannot remember for the life of me where the settings I have used 100 times in the past are for dimming or turning of the button lighting.
2, Started getting random reboots a few weeks ago that I at first contributed to build.prop line testing or under vaulting but after it started happening in CWM why either backing up or restoring I was able to do a few tests and it looks like my SD card may be at fault. Just for the heck of it decided to run the erase SD card option in the storage setting but just says checking SD card and that
When playing Sleepy Jack at some parts of the game the screen flickers and gets pixelated and I can hardly see. When I also play games on GBCoid the sound crackles and lags.
BTW are these sound crackles new to this build and didn't exist in 03-01 & before?
New build uploaded, updated graphics driver, up to 2x the framerate (let me know if you notice any game improvements other than just nenamark2 benchmark).
I did this again with wiped clean ROM and cleared cache with just only Bouncy Mouse Free that I downloaded with Clock speeds set at 61-1024hz. It does exactly the same result. It would start game and then I'll crash in about 2-3 seconds. Thanks for the ongoing effort, I'll keep the fresh for a few hours.Try factory wipe & clean install of the ROM, otherwise it could be some cache or setting build-up from other apps that's causing problems.
hey whyzor! you wanna know a weird bug with 3-01?
when your on your lockscreen and you are using the sliders (like vanilla android)
slide right above the unlock slider and it will take you to the dialer!
this is without and other options enabled, its like theres another slider there but theres not!
I'm like a little kid in a candy store waiting for a new ROM. Each one is better than the last. Thanks Whyzor!
I did some testing with AnTuTu Benchmarking which benchmarks 2D, 3D graphics and other apects of performance. The 3/4 build is over 15% faster in 3D (865 vs 734) with no loss of 2D. However the RAM speed did slow from about 363 to 295. The base benchmark is an average of the last 4 builds - and these builds showed little variance in ROM or 3D speeds until the 3/4 ROM.
whats the best way to calibrate battery after flashing this, i cant get it to charge past 87%
It is not true, played many games on the CM7 ROM including emulators and each and every one of them ran fine. At least for Bouncy Mouse Free, the version requirement is 2+ (link) and I never had a phone crash prior to update. I will try to replicate this again on the 3-01 Build with WhyKernel 2-29 and give you more results. At the moment I am not gonna be able to try anything until Thursday.For all the game problems. The CM7 ROM has never been able to run all the games that the stock ROM could (either a Froyo vs Gingerbread thing, or a buggy game app), and I'm not going to dig into that to try to fix it. I can only try to figure out if any of MY recent builds have broken things.
New gen is fine but I love the classics most.I would just play games on my ps3 jk jk
Just an Update: Radiant HD crashes my phone.
I also tried Where's my Water, Hot Donut, Muffin Knight, Fruit Ninja, Puffle Launch, and Pinball Ride. These games are okay but I do not see a smooth gameplay. All running under 245-1024hz (Stock) frequencies.
EDIT: I like the capacitive button delay of 250ms, this I like![]()
