su
mount -o rw,remount /system
cp /sdcard/libaudioalsa.so /system/lib/
cp /sdcard/liba2dp.so /system/lib/
chmod 644 /system/lib/libaudioalsa.so
chmod 644 /system/lib/liba2dp.so
reboot
Mines a July 2011 Phone. I have no idea, Clean or Flashed over, same result.I m using new GPU driver's for a long time know on my CSL-MI410. this have improved my gaming experience a lot. i have played lot's of game's with new GPU driver, like :- Modern combat 3, ShadowGun, Asphalt 6, Reckless Racing 2 & Many other's they are lot smoother with new GPU driver's & they are lot chopper with older driver. idk why this problem is coming with your device although they are basically the same device...!!
I have tried that, placed the Build 3-01 files and "replaced" them with the exact permissions as shown in the screenshot:Those who are having game problems can also try copying the previous GPU binary files from a previous ROM using the same procedure as above. The files are:
/system/lib/libgsl.so
/system/lib/egl/libEGL_adreno200.so
/system/lib/egl/libGLESv1_CM_adreno200.so
/system/lib/egl/libGLESv2_adreno200.so
/system/lib/libq3dtools_adreno200.so
libgsl.so is supposed to be in the directory above 'egl', the rest in 'egl'.
I can confirm that RAdiant HD is causing my phone to reboot on the 03-04 build. I installed it under the 3-01 build and it played amazing. I will try flashing over the files to see if it makes a difference.
The "Radiant Free" also plays smooth on the 02-02 build. Not sure about the HD version. I'm not paying for a game to test if it works or not. Sorry![]()
I can confirm Plants vs Zombies is running much smoother on the 3/4 build with updated gpu drivers. So far all the games i've tried either run average or above average than they did on previous builds with no force closes.
can i adjust the battery charging led light cause it turns green at 90% and i want it to turn green when its fully charged
some help?
I'm thinking the new GPU drivers will stay since it works for 90% of the games and users out there, only a few aren't working.
Whyzor, you are a lot more patient than I am. You answer a lot of questions, many of them you have answered before, without appearing snarky. A real exception in the world of tech. Big thanks for all your work and help!
