yashwantsingh
Is WhyKernel 02-29 is included in the new rom update or they are needed to be flashed separately ??
Bad Luck! Still Touch screen is not working, on other fbo devices...!!
Ate the build prop lines to fix the after call time etc included?
Great build.... i really like the blue theme in this one. I have a question, Whyzor. I like a bloat free phone with minimalist apps as its quicker and the battery life better. You stated previously that it was safe to remove certain apk apps and i was wondering if that is still true with the current build. Specifically, i'd like to remove the following and was wondering if i do...would it cause harm to the new ROM:
rm /system/media/bootanimation.zip
rm /system/app/RomManager.apk
rm /system/app/Androidian.apk
rm /system/app/CMStats.apk ****** (I see this running in background but I dont even use it)
rm /system/app/CMUpdateNotify.apk
rm /system/app/CMWallpapers.apk
rm /system/app/Cyanbread.apk
rm /system/app/DSPManager.apk ****** (Is this app necessary? It also runs constantly)
rm /system/app/Email.apk
rm /system/app/MagicSmokeWallpapers.apk
rm /system/app/Pacman.apk
rm /system/app/Protips.apk
rm /system/app/ThemeChooser.apk
rm /system/app/ThemeManager.apk
rm /system/app/VisualizationWallpapers.apk
rm /system/app/VpnServices.apk
Is there a changelog for 3-1 kernel? Also why did you feuitninja scores improve?
Gotcha. I meant what do higher scores mean,? Gpu touchscreen changes,?
is there a way for cm7 to have a full in-coming call screen w/out installing any apps. Its the only thing that is keeping me from changing to this rom from MIUI. i've tried apps before but they are laggy...
from what ive read, its not a triumph problem, its a Virgin Mobile problem
Any thoughts on why everytime I upgrade to the new CM7, I lose the Facebook App?
Edit: Nevermind. I found it in Titanium Backup, and it was set as a system integrated app. I changed it to User and I should be fine now.
