dsmryder
Android Expert
Is anyone else having problems with constant lock-ups and force closes?
Some people do. It's either caused by bad apps, their left over data from a previous flash, or a hardware issue. Bad settings can do it too.
Did you change any settings when you loaded the ROM? Have you tried to reflash, maybe after checking the md5 check sum. If you reflash, I would try to load only the necessary apps that I needed, just to eliminate them.
Hope it helps
