Is this ROM totally missing a voicemail app? I just left myself a test voicemail and all I got was a text saying to call a number to get the message ... I can't seem to find an actual UI.
Does LauncherPro work with Froyo? I couldn't find it in the appstore, and had to install it manually... ADW.Launcher seemed to lag when I was opening my app drawer, any idea anyone?
Quick question - if I want to update to every nightly, do I need to wipe the data/cache/etc? Or can I just do the "install from zip" method? Or use CM Updater?
You have to install it, i cant find where i got it from, but uploaded it here:
Sprint style Voicemail
the one thing that has frustrated me since I rooted and got free wifi tether is the super slow speeds when I tether my iPad with my evo. when I used the one that came from the factory with the $30 service is was super fast.
anyone else notice this? any fixes available? can I just install the apk for the original wifi tether, pay the $30 and use that with my cyanogen6 rom?
thanks
p.s
I am only getting maybe 150k dl speeds, but about 400 up. I usually get around 1.5 on my phone when I test the 3g speed
update:::
now I am only seeing speeds of about 500k in boh directions on my 3G signal, about three bars
Question..... can I update without having to wipe my data every time?!?!
I just installed Mod 9 7-23 and I am not able to see google voice in the market. Can anyone instruct me on how to get it back. So far the rom seems snappy and my MFLOPS are 41!![]()
read the thread
seriously this question was answeredsixfive posts above yours
Seriously.... thanks.... what we in the 3rd grade. I'll admit I should have read, but don't get all bent outta shape...
Anyone know if facebook integration for contacts is working because I can't seem to get it to sync my contact pics
Go here http://forum.xda-developers.com/showpost.php?p=7260239&postcount=872
This is the fix for Facebook sync issues. Instead of using the adb push/pull method you could aslo use Root Explorer to make your edits. Also, if that doesn't make sense to you run a search through the CM6 thread on XDA, there are other explanations listed through the thread and they might be a little easier to perform. Keep in mind that after you do these steps and you've redownloaded Facebook for Android, open the app and login before you go to menu>settings>accounts & sync... once you log in facebook should show up in your sync menu.
Thanks, I'm looking into it now... I found another issue that seems to almost be a deal breaker for me... no cut and paste?!?! Is this resolvable? I'm talk'n about the updated C&P that has te nice handles and all??!?!
my only problem with this is no sence i like the pinch and 7 screens
i can pinch and see all seven screens...
Has anyone had issues with the top status bar disappearing from their home screen with this ROM? I'm guessing it's a quick keystroke or something else I'm missing, but I can't seem to get it back.
