What error are you getting?
Here's the text of the email:
Starting recovery on Sun Feb 5 19:53:46 2012
framebuffer: fd 4 (320 x 480)
ClockworkMod Recovery v5.0.2.7
recovery filesystem table
0 /tmp ramdisk (null) (null)
1 /boot mtd boot (null)
2 /cache yaffs2 cache (null)
3 /data yaffs2 userdata (null)
4 /misc mtd misc (null)
5 /recovery mtd recovery (null)
6 /sdcard vfat /dev/block/mmcblk0p1 /dev/block/mmcblk0
7 /sd-ext auto /dev/block/mmcblk0p2 (null)
8 /system yaffs2 system (null)
W:Unable to get recovery.fstab info for /datadata during fstab generation!
W:Unable to get recovery.fstab info for /emmc during fstab generation!
I:Completed outputting fstab.
I
rocessing arguments.
I:Boot command: boot-recovery
E:Bad boot message
"recovery "
mtd: successfully wrote block at c7de400000000
I:Set boot command "boot-recovery"
I:Checking arguments.
I:device_recovery_start()
Command: "/sbin/recovery"
ro.secure=0
ro.allow.mock.location=1
ro.debuggable=1
persist.service.adb.enable=1
ro.build.id=GINGERBREAD
ro.build.display.id=full_lg690-eng 2.3.7 GINGERBREAD eng.koush.20111216.142759 test-keys
ro.build.version.incremental=eng.koush.20111216.142759
ro.build.version.sdk=10
ro.build.version.codename=REL
ro.build.version.release=2.3.7
ro.build.date=Fri Dec 16 14:28:29 PST 2011
ro.build.date.utc=0
ro.build.type=eng
ro.build.user=koush
ro.build.host=Koushik-Lion.local
ro.build.tags=test-keys
ro.product.model=Full Android on Emulator
ro.product.brand=Android
ro.product.name=full_lg690
ro.product.device=lg690
ro.product.board=lg690
ro.product.cpu.abi=armeabi-v6l
ro.product.cpu.abi2=armeabi
ro.product.manufacturer=unknown
ro.product.locale.language=en
ro.product.locale.region=US
ro.wifi.channels=
ro.board.platform=msm7k
ro.build.product=lg690
ro.build.description=full_lg690-eng 2.3.7 GINGERBREAD eng.koush.20111216.142759 test-keys
ro.build.fingerprint=Android/full_lg690/lg690:2.3.7/GINGERBREAD/eng.koush.20111216.142759:eng/test-keys
keyguard.no_require_sim=true
ro.ril.hsxpa=1
ro.ril.gprsclass=10
ro.config.notification_sound=OnTheHunt.ogg
ro.config.alarm_alert=Alarm_Classic.ogg
ro.kernel.android.checkjni=1
ro.setupwizard.mode=OPTIONAL
net.bt.name=Android
net.change=
net.bt.name
dalvik.vm.stack-trace-file=/data/anr/traces.txt
ro.factorytest=0
ro.serialno=
ro.bootmode=unknown
ro.baseband=unknown
ro.carrier=unknown
ro.bootloader=unknown
ro.hardware=thunderc
ro.revision=0
init.svc.recovery=running
init.svc.adbd=running
I:Checking for extendedcommand...
I:Running extendedcommand...
Waiting for SD Card to mount (20s)
SD Card mounted...
Verifying SD Card marker...
43135c84f2bd716b59381368be86d04b
I:Running script:
I:
ui_print("ROM Manager Version 5.0.0.5");
ui_print("February 5, 2012");
ui_print("Preparing to install ROM...");
run_program("/cache/dowipedalvikcache.sh");
format("/cache");
format("/data");
format("/sd-ext");
assert(install_zip("/sdcard/clockworkmod/download/
developer.clockworkmod.com/downloads/480/1949/CM-7.1.0-LG-MS690-10182011-signed.zip"));
parse returned 0; 0 errors encountered
February 5, 2012
about to run program [/cache/dowipedalvikcache.sh] with 1 args
mount: mounting /dev/block/mtdblock1 on /cache failed: Device or resource busy
Formatting /cache...
Formatting /data...
mtd: not erasing bad block at 0x030c0000
Formatting /sd-ext...
I:Formatting unknown device.
rm: can't remove '.' or '..'
-- Installing: /sdcard/clockworkmod/download/
Finding update package...
I:Update location: /sdcard/clockworkmod/download/
Opening update package...
Installing update...
script aborted: assert failed: getprop("ro.product.device") == "thunderc" || getprop("ro.build.product") == "thunderc" || getprop("ro.product.board") == "thunderc"
E:Error in /sdcard/clockworkmod/download/
(Status 7)
Installation aborted.
result was NULL, message is: assert failed: install_zip("/sdcard/clockworkmod/download/
