dsmryder
Android Expert
Is your widget app on an SD Card? Make sure all widget-including apps are on the phone's internal storage.
if there's an update to an app that the widget uses, the widget would need to be reloaded.
As for the clock, you can manually drag it to the middle.
LOL sorry about that man, I am to easy going to flame some one on the boards. Anyways yeah I installed Zeam Launcher and all I can say is WOW! It's basically 389kb and runs like a speed demon. It's not as smooth as 360 but it's darnn close. Here is a screen shot I just took.
While it doesn't have the ICS middle app button it looks fine to me. Plus gmail no longer had the highlight of green in it like it used to after applying the ICS theme. Also the other feature I like is when you apply a theme from the Theme Chooser you normally need to reboot to apply all the icons. With Zeam you can just restart the launcher on the fly. Very practical launcher IMHO and also no Chinese LOL.
Thanks for axing the bloatware, G60. I currently have cm7 reloaded and its time for an update . cant wait to install this rom over the weekend.![]()
i dont know if this was talked or brought up before.... but on stock i can send 20second mms videos but using this i can only send 5second ones. Just wondering if its fixable or something![]()
I'm sure this has been asked before but if I'm coming from Whyzor's last build, can I flash over or clean install?
I will look into this and verify (truthfully I don't send MMS). If it's an issue I will put it on the bug tracker.
Does anybody have a new CM7 gapps package that has Google play instead of Android market? It gets annoying when it takes a while to auto update.
How'd you get your google bar to look like that?
This morning when my alarm went off, there wasn't anyway to dismiss it. No pop up window and couldn't access it through the notification bar. Anyone else experience this?
Sounds like just the alarm clock I need!
Thanks for the update removing the extra apps. I much prefer a minimal version that I can customize myself.
I seem to be having problems with widgets not displaying after installing this update, though. In the widgets' place, it just says 'Problem loading widget'. Anyone else having trouble?
g60! this rom is great! smooth but the only downfall for me is the battery life. for me i get like 3% wen idle...compared to miui with less than 1% per hour wen idle.
