dsmryder
Android Expert
I also have been routinely losing my WiFi connection with this latest version of the ROM.
What is the sleep policy for your WiFi?
Settings--> WiFi settings--> (menu) advanced settings.
I found a post that may be of assistance:
http://androidforums.com/internatio.../476035-how-change-default-system-sounds.html
Can anyone tell me where startup/shutdown audio files should go on this ROM?
Or you could have flashed my mod for that, from here http://androidforums.com/triumph-all-things-root/547143-mod-zeam-launcher-cm7-g60-style-r0-6-only.html that also changes the look of the folders and removes the home icon from your app drawer.![]()
It seems that Android does not natively support GIF images. That is probably because they are a proprietary format, and supporting them would cost the Android project and or Google copyright royalties. But the good news is I found a good app on the play store, right here. Also, if you like the app enough and really want to use GIF wallpapers without that dumb watermark, please purchase the Pro version. It also helps support development. It apparently supports GIF wallpapers. Please tell me if you've had success.
(re: startup/shutdown sounds)
Check this thread CM7 / AOSP Boot sound [working] - xda-developers
He has made a script to allow you to have boot sound.
I have no personal knowledge of it, but apparently it works with CM7, and looks simple.
The first thing I did to my stock ROM after rooting was to disable the boot sound.
Is there a way to change the font of the clock on the lockscreen to ICS?
It's set as "Never"
Actually, it just happened right now. Phone was charging, unplugged it, checked my WiFi Sleep setting, was connected to WiFi....and just checked a few minutes later and it's no longer connected.
Then, it started connecting again on it's own...and connected. Actually, it's also not staying connected when I press the power-off button once to turn the screen off.
Get Roboto.ttf, rename it to Clockopia.ttf and copy to your /system/font directory, overwriting the original.
Whyzor had Roboto as default font in CM7 reloaded before... Is it gone now?
I just rooted and installed this rom on my phone a few days ago and i noticed the stock 2.2 volume is much louder than the volume on this rom. I was just wondering if the current volume level will stay like this or will there be any other possible audio changes in the future to improve volume level? I am one of those people that listen to music alot thats why i am asking![]()
Sends it into a bootloop
sh (the location of the bootsnd.sh file)
Make sure permissions are correct.
Duh! I keep forgetting to check permissions, worked like a charm. It was just a matter of finding the correct font. Thanks!
I am getting a Force Close when attempting to install and use the 360 Launcher in R0.6. So far 360 launcher is my favorite even with its wonky lock screen. Thanks.
The thing is that you can only adjust DSP manager to a ceratin point untill the sound is distorted. Theres a difference between adjusting eq levels and increasing actual volume.Use dsp manager to adjust the settings and eq levels for louder volume.
