G
g60madman
Guest
Let me start off with the fact that I love and appreciate the work g60madman and you others have done for the Triumph. I look forward to EVERY update.
Now for the complaints. and maybe someone can shed some light.
For me, the past 2 updates (R0.5 & R0.6) have resulted in my phone being extremely laggy and unresponsive. It may have been something I have done because everyone else seems to be fine with it.
I have tried both a straight flash over the previous install and also a clean install after factory restoring the phone and neither have seemed to make a difference.
Also, what is up with that "Home Sample" option. Does anybody like that or is it needed for the other Home Replacement options?
Thanks for any help, until then I will just stay with R0.4...
Happy Modding
Home Sample is the base launcher that is in gingerbread. When I removed launcher2 this is the one bellow that. As for the issues you are having I have not had any problems. After a full wipe and load everything is working fine. Do other roms besides r0.4 perform normally be it muiu, ics or other flavors of cm7?
