A simple tweak that should be doable is putting in Roboto as the default font. At least I hope it's simple...
It was in reloaded.
Not sure when it went away.
Loving this, but it seems so bare without a custom launcher, maybe you could add zips to a variety to the op
:thumbup:Haven't tried since Whyzors final, but will soon... great job on keeping this alive:thumbup:
BetterBatteryStats will show any wakelocks that my be holding up the system. I would start there.
What launcher seems to have the best response on this rom? Zeam has been working pretty well for me. My wife has go launcher and it seems laggy to
me.
I got BetterBatteryStats and one of the culprits is WLAN_lock, which seems to be JD Ultimate's fault for not shutting down the WiFi when screen turns off. Do you guys know any good app that turns WiFi off when screen is off? That's the main reason I'm using JDU.
The other culprit is bq275x0 and I have no idea what that is. I'm guessing it might have something to do with the 360 Launcher (i'm running r.04).
me.
I don't know of another program that will turn off wifi, but what I use is the notification widget. Very fast and if I'm on wifi, the I probably want to connect to my network. Or a big download.
Does Smart Shortcuts allow you to change the look of folders on the homescreen? I have that app but it seems to only be wanting to change folders on the SD card, not the homescreen. Would still love to get clear folders but don't want to have to use Go launcher to do it. I like the smoothness of Zeam.
I still have the low volume issue most of the time. I have to reboot and kill all of my apps a few times before the volume goes back to normal.
