Hey g60, have you noticed that when on call, it locks the phone very quickly meaning whenever you hang up you have to unlock the phone because it brings you to the lockscreen?
I wonder if there is a way to keep it from locking the phone while in call? I'm gonna look into and see what I can find! Anyone else with this issue?
There is a way that you can alleviate, but not solve this issue. Menu > Call Settings > Keep screen awake. I'll report a bug to see if g60madman can tweak this for the next release.I have the same issue as well, don't know if there is a way to fix it, but i just learned to deal with it.
Yeah I tried that. Still don't help much. I'm thinking about looking in the phone app itsself and see if I can add an option to keep the phone from locking while in call!
I'm going to have my brother look at the phone and settings repos because he is alot better with Java than I am so he may be able to help me out!
It's the Ice Cream Sandwich theme for the Theme Chooser. You should try it out. If you don't like it, uninstall it.
Just curious, is under volting working correctly in your ROM? I have all my voltages set at 600 and it isn't crashing or anything.. I just find this peculiar since I've set it before to see the lowest I can go and not all were able to go lower than 800.
Yeah, my theory on it is that anything below 800 just errors out and runs default voltage.
Not just this ROM though... any that have a kernel with that extended voltage regulator table.
For the people with issues when in bright light, there is a setting in CyanogenMod settings/Display/Automatic backlight, I can't remember off hand which one now, it was either Apply moving average or allow light decrease, I have them both enabled and it works. There is a slight delay, sometimes about a second or so but the screen brightens up. I didn't change any other settings just checked the box to enable.
