How do you get that much time? I have wifi/bluetooth disabled, Data on, Autosync on. I also have a push exchange email account set up. I get maybe 18 hours. That is no phone calls and about 15 to 20 sms a day.
Just curious if anyone has had problems with charging. I will connect my phone to the charger and after a few minutes it will say battery is at 100 when it was only at 30 .. and it stops charging when it gets to 100 after I unplug it for a few more minutes it drops back down to 30. This isn't happening all the time but it is a reoccurring thing.
Any one else running into this?
Try rebooting into Recovery and going to Advanced > Wipe Battery Stats. That may help.I've been having charging weirdness too. At home I leave my phone plugged in to the charger all the time, my home phone has a blue tooth link so any cell calls get routed to the home phone. Anyway what I notice is when I plug the charger in the red charging light comes on and the screen displays the batter charge level---all as it should.
Then at some point the green fully charged light may cone on, again as it should, but a few hours later there is no charged or charging light at all. If I check I will see the battery is discharging. If I unplug the cable and reconnect it I may get a report that the battery is at 63% or something and it begins charging again. If I don't use the phone for days this process will repeat.
I will say i did not have this issue when on the stock ROM. Not sure where the issue lies.
There are many forum threads out there about the faulty USB port on the Triumph itself. Forget the cable/battery/battery stats/etc, it often comes down to a bad port on the phone. I have 2 units with the same problem.
Following the advice of these threads, this week I called VM and patiently followed their "troubleshooting" steps and without hesitation they replaced the Triumph. As I type this I'm loading this *awesome* ROM on the replacement phone that arrived today.
Since this thread is ROM related, I recommend some googling and/or starting a thread about it.
what number did you call? I called said "Trouble shooting" and got only 3 options, calls, email or internet. No options for anything else.
Please, nobody attempt to activate this phone on any non-stock ROM. I recommend that you activate with stock, back up stock, then flash to your desired custom ROM> I attempted to activate my Triumph with a custom GB ROM, and I got nothing but errors during the activation calls. It will just be a massive pain, and if you call tech support, you will do nothing but tick them off. You MUST activate with stock (I'm not sure, but some Froyo ROMs may work). I do not care how you activate (over the phone via calling, online, or whatever) it will not work on most custom ROMs.
Not sure if I'm going to install the new r0.10 or not; I'm happy with the camera I brought over from whyzors cm7 (and subsequently flashed to r0.08).
Haven't had hardly any issues that warrant wiping and installing the new build ... but still curious to try it out!
So yea, it's not listed as a known problem. Here's my original post:
http://androidforums.com/triumph-al...-r0-10-6-03-12-a-post4388651.html#post4388651
Thanks gar. I will add this to the bug list.
Whyzor disabled auto focus in the video mode to prevent that. I don't think I'll be able to find the post today, but it was a while ago. I bet that's what is going on
Complete new flash, volume bug during music playback still seems to be there.
Great battery life though, and awesome work![]()
