G
g60madman
Guest
That is what I thought, and that is exactly what I did. I even tried the "Back to Stock" route.
I am aware of the longer-than-normal first startup, but after it has been on the g60 logo for 20 minutes to an hour, I think that it isn't going to continue.
Pull the battery and wait 20 seconds. Plug back battery and boot back into CMW
wipe data/factory reset
wipe cache
wipe dalvik cache
reboot into CWM
install 60style r0.10
install gapps
install gapps talk (if u use it)
reboot
If it takes a long time to boot again. I would recommend downloading the ROM again to make sure you don't have a corrupt .zip.
