G
g60madman
Guest
Bump - Check the first post I have updated g60 to have my the new headset fix on reboots, no more plug unplug after reboot. Also included fix for auto brightness with link.
g60, thanks for the fixes! Do you plan on updating to patch the camera when dsmryder has it figured out, and also incorporating Chairshot's GPS improvements from the starship ROM? It sounds like he's managed to make some major improvements, and this is the only "stock" CM7 ROM.
Those fixes will be held off until the new release of CM7.2 is done. Can't give you everything or you won't try my new ROM LMAO![]()
Yes, video fix is a kind of a big deal for me.
Thank you!
any ideas on why I am getting such a poor network connection?
Virgin Mobiles crappy service?![]()
yeah, something is def wrong. I ran speedtest three times and got 120, 115, and 118 kbps. I used to be able to get 10x that speed under TG's ROM. My upload speeds are twice my download speeds
Such a nice ROM too. Oh well, back to TG.
Hmm I'm curious as well, time to do some testing![]()
if I download the latest from Index of /download/cm7/final - is there 3G fix in current version?
