I think I have made a major breakthrough on CM7. Here's the deal, after reading the candy crush thread and thinking about how I changed the ICS kernel for gaming, I tried to use the same process, but really long story short, it didn't pan out. But, the EGL drivers from the Xperia Play did help a lil bit. So after many failures, I decided to just try the latest PA ICS kernel.
Here is the deal, I play Simpsons Tapped Out, and it seems to be a pretty hardware intensive game. I tried it on 03-03 and it would barely load or play, I tried updating the kernel and it got a tiny bit better. Then I got the CM7 Play EGL drivers and threw them in the ROM zip, with out the kernel, and that made the biggest difference. Then the updated kernel, but that just black screened after Moto logo. So then I reflashed the ROM w/EGL and said F it let's just see what the new ICS kernel will do, since the actual kernel is mostly compatible across platforms, it is the Ramdisk that is OS specific.
Long story short, the game played almost as fast as on ICS.
This was just a very quick run through, and no other testing was done as far as other hardware components. But this may be a game changer for CM7, literally ... lol.
