Root [ROM] MTDEV-CM7 build 2013-03-03
I thought that sense chairshot had access to the FTP he would use it.
If you go to dl.mtdev.us you can get the test build I made with the security update. The latest one from him is 20121227. Mine should be similar, but the ROM is smaller as I removed support for other languages and non hdpi devices.
Has any progress been made on the GPS? I had to switch to the VM ReVamp of 2.2.2 to get a GPS that works consistently, but I'm really missing many of the conveniences of CM.
I have not touched the workstation in a few days. I just got someone else set up and I hope I can lead him to some ideas for CM9. That will give me the oppertunity to work on this ROM. I know that some of the ForYo ROMs have a fast GPS and I would like to play with that and WiFi. Before that I promised I would backport the quick settings idea from JB. I have glanced at the code and it shouldn't be too hard. I might do it in parts just to get things moving.
Holla.
What's wrong with my phone??
It happen before.. The one replacement phone from VM and get reboot whenever make or received call. As soon as i heat someone speak, it shup off and reboot. The first one replacement back on Dec when open this problem here but after couple reflash or i can remember what i did. it fixed by itself.
This time, i ordered a replacement phone from VM becuase one of loudspeaker broken. As soon as i received from VM, I login VM website and swap the IMEI # and I tested it for make and received call, data and text. Then I swap the Recovery.img, boot in cwm to backup the original rom. And then wipe, format and Davik wipe etc.. After that, I flashed 2013/03/13.zp and flash Gapp.zip in. Reboot, restore all apps from Titanium. And then i realize that problem.
I went back to CWM and wipe, format and Davik wipe again, I tried to install the 2013/03/13.zip, and 2013/04/14 and even the 2013/6/17.zip and still have this problem. What have i did wrong?
I'm going restore orginal rom or maybe install sharp rom see any of this problem.
Update.. I'm trying to restore with original rom with CWM 6.x.x and complete. it up hang in Motorola logo screen.
I flashed Sharp rom and fix the problem.. No don't know why.. Now, wiped and flash back to this rom built 3/2013 built and work now. Just pain in my ass.
thangfish... I saw you quoted on 2013/4 build. what different from the 2013/3??
Going back to the 12/28/2012 fixed the tethering issue. Switch back prior to the 4th July weekend and forgot to report my findings. As soon as we ride out our Virgin Mobile balances we will be switching to PagePlus $30 plan which now includes 500mb data. Service was so spotty near Miami it pushed me over the edge on giving up on Virgin Mobile. Have two brand new HTC One V that will will never use since they never killed off the grandfathered $25 plan. This was a good phone and I appreciate all that worked to make it better. I check in every few months to see if there is a better build than this one to install. Will probably extinguish balance toward end/beginning of year.
wifi stopped working for my phone. It connects to wifi and says its connected but doesnt actually work?? someone help :(
the way to test if it's the ROM is to make a backup, I suggest two. Then wiple and flash a ROM. In your case you could flash the ROM you are using. You would still have to wipe, just flash afterwards. That will allow you to test if it's on your phone side or the router side.
fresh install of MTDEV-CM7 build 2013-03-03 NO SOUND and working great. I don't even have the video recording clicking sound if I use IgCamera. One thing that I can't get to work is vibrate on notifications. When I have the phone in silent and set to always vibrate, I only get phone calls to vibrate, but not notifications. I've dug all around the settings and I don't see what could be wrong? Any Ideas?
Check the apps them selves. Some will do system notifications, some will to their own. This would apply to the preinstalled apps and the ones you download.
Let me know either way please.
haha... I don't remember having to do that on the stock ROM, but yes there was a setting in the "messaging" app that came with this one that was set to never in the notification settings. Thanx
:thumbup:
I was just curious if with the latest build if audio plays over USB? Just considering buying a new car stereo and wondering if local music or Pandora would stream over USB.
Also for anyone having wifi/3G issues (mine says its connected, but doesn't actually connect to any websites), I just do a backup and flash to stock and back. Not sure what causes it, but it happens every so often for me
The best I can tell that no ROM could allow this. From what I know the radio (the host) is looking for a certian responce that the devce would give. The phone (as well as partitioned devices, like my bootable USB drive, and media readers) are looking to make a conversation. Basically it uses a different protocal to work.
You could prove me wrong, though
Ok, I guess this is going to be off topic and TMI :D
Jelly Bean was touted as having support for audio streaming via usb. Apparently you must have devices that support Google's format.
Normally, usb audio streaming via usb is digital DATA, as opposed to analog audio (like you get out of the headphone jack).
This means that data is streamed into *something* that has a DAC (digital/analog conversion) chip.
In the audiophile world, high res digital audio is streamed from a computer (preferably at a high bit rate) using a capable software player, to an external DAC, (bypassing the crappy one on the sound card, or phone) which is then hooked to an amp (speaker or headphone amp) with normal stereo cables.
All of the usb ports that I have seen in car audio stuff just use the usb port to mount external storage devices, like a flash drive, or maybe even a hard drive (with a file/directory limit).
A car audio system has to have a DAC if it plays CDs or mp3s, so it shouldn't be difficult to manufacture that capability.
Here is some info on a digital audio streaming capable player for android.
USBAudioRecorderPRO
Here is some info on results with various devicesAndroid phones and USB DACs - Page 150
I have been REALLY hoping that Google could get standard support into android and get the proper hardware into a device (moto??) so we could use our phones for high quality audio...
Thank you all for the replies and your detailed explanation thangfish! (It was interesting) I think I might just stick the cheap route and use an AUX cable for my Triumph and have a USB for my girlfriends iPhone (which apparently is supported via USB, lame!).
Looking at this head unit here: Amazon.com: Kenwood KDC155U In-Dash Receiver: Car Electronics
It listed "Kenwood Music Control for Android Smartphones". I followed the link to the app download and it said:
"Connecting your Android device in which this application is installed to your Kenwood audio system via a USB allows you to control the audio system: for example, searching for a song in the Android device by artist name or album name."
So I'm assuming that it just mounts your android and lets you play your music through that? Cause I would definitely rather use USB to simultaneously charge my phone while playing music
I would assume so too.
I was actually hoping somebody else would mention something new that we don't know about yet.
What we have is usable, but definitely not optimal.
The whole thing seems to be on the verge of something good, but it just ain't there yet.
did you read the reviews?
Radio does not recognize ipod touch, iphone, or android phone. I downloaded app for radio on play market and radio still wouldn't play thru my android phone. Waste if money. I'll just go to a local store next time so I can at least see if display models of radios work with my phones
For a simple CD player it do its job very well. The interface is easy to use. It works perfectly with iPhone/iPad, but I couldn't use with Android devices besides the documentation said it should work.
This is described as KDC-155U but what I received is the KDC-MP155U which is not iPhone/iPod ready. After receiving the radio, I looked at the manual and everything regarding iPod/iPhone said "except KDC-MP155U". I wrote to Kenwood and this was their reply:
"I want to explain the difference in the models as you have included two different ones. The link you provided is for the KDC-155U. The model you purchased was KDC-MP155U. I apologize but you purchased the wrong model radio. You should have purchased the KDC-155U instead of the MP155U. I would advise to have it exchanged so that you may use your iPod."
