did I miss something?!?!![]()
Do it!![]()
g60MADMAN,
I have a question? You know I have replaced my phone and now I think the newer triumph has updated version and do I have to install 4v or 5v recovery mod in order to install any custom rom?
I think I found it
I also found what happened to a car's PCM one time
The driver for the A\C was reversed. Wierd stuff.
Hey, awesome job on this, really!
Been using this with default settings for about 2 weeks and here are the only problems I've found:
- WiFi could use some improvement to stay connected, has problems using Groove IP (Google Voice Calling) for longer than 10 minutes, if I'm lucky, where I had no problems in that area with other ROMs.
-Signal/3G is randomly lost at times, and not because of VM. Only way to get it back is to reboot.
-Battery drain seems faster on the latest build compared to the previous one.
Wow, that's not at all what I expected, but an interesting read none the less.
So, to summarize, strange things happen to chips internally, at the atomic level, at a faster rate when operated beyond its design specifications, accelerating it's ultimate demise.
Thanks for posting, Ryder.
Yeah, it's obvious that electricity has "force" and much can do things that aren't expected.. Sooooo, takes it easy when overclocking.
Hello, Just wanted to say !!HI!!
and chec
more the merrier!!
Well hi!
MT Dev team
I've been having a problem where when the screen shuts off and the phone locks I cant get the screen to come back on. If I push the side button on the phone nothing happens and I have to do a battery pull. The weird part is that it only happens sometimes during the day. I thought I fixed it by turning automatic brightness off but It's still doing it and I can't really use my phone at the moment even after restarting.
So after two weeks of use, a couple of basic observations I wanted to put out there.
First, browser syncing doesn't seem to work for me. It just gives an error ("Sync is experiencing problems. It will be back shortly.") whenever I try. Not sure if this is normal or just me. Everything else syncs fine, even chrome.
Second, Battery life isn't great. I get about ~15-18 hours on my 2000mah extended battery, which is a lot less than I got under cm7 (which got me 36 hours or so). I am running Easy Battery Saver and keep wifi turned off pretty much always, and have it set to sync once an hour. Having autosync turned on or off doesn't seem to make any difference. I only use it lightly (check news, listen to music/audiobook on walk to work, check emails occasionally). I Use Smartassv2, and my max clock is 1.4ghz, min 61mhz, and I use the autobrightness. Anyone else noticing less battery life on this?
My battery life on this ROM is much, much better than it is on CM7. I'm no expert on this stuff, so I have no idea why. Battery life seems to vary wildly from user to user no matter the ROM.
