∙ Removed GoogleNow
∙ Added com.google.android.media.effects
∙ Added in Cherry GPS files
∙ Added in Sharp sensor file
∙ Fixed Wifi Tether
First and foremost I removed GoogleNow as the Voice Dialer did not work over Bluetooth. Since our ROM's are about keeping them as simplistic as possible you can install what ever you like as the ROM is now down to 110MB so GoogleNow will work. I added in com.google.android.media.effects which helps with the overall performance of the ROM it is much more smooth than before. In updating the Cherry GPS I was able to get a lock in under 1 minute being out side. There was also some changes to the GPS code TickerGuy wrote as I corrected our AMSS version to be 6225 based on our Kernel. The sensor file should resolve the blasted black screen when some one hangs up on you. Also WiFi Tether should now be working but I need some testing done.
The Camera is still not working but something I am still working on. Just based on all the builds I have been doing as of late I decided to add in more fixes for multiple things. Hopefully our next release will have a working Camera
Enjoy!
-g60
