Grumpy Zombie
I installed the one on the link but the card telling me to update continues to show up.
Did you install the Offline version or the Online version of GoogleNow? The version I included in the ROM originally was Offline and should leave you with about 20MB and or so.
Repartitiong would be nice, but I would imagine to be very dangerous, then we would have to repartition back when installing the stock rom. Ill look into seeing how ro repartition a emmc device like ours but I can't promise anything! I wish you could combine three partitions together as one!
Yeah I edit the updater-script to add the GoogleNow into the hidden partition and link back to the system but could not get it to work. Good luck man! It would be sweet if you could figure it out but I agree it's dangerous.
Yeah I just mounted both spare partitions one as /hidden (/dev/block/mmcblk0p9) which has about 25mb free formatted as ext3 and the iteration as /hdata (/dev/block/mmcblk0p10) which has like 67mb free.
So maybe if we have the script format those as ext4, then have our init mount it as /hidden and /hdata at boot. Then in our update script have some of the less complicated but still large apps from the system copied to one of those partitions and symlink to /system/app. Kinda like Motorola and vm did with their apps on the stock rom. Or move ringtones over to their as well!.
We just need to make the update script fool proof no matter what recovery you are using. Because my new cwm recovery makes /hidden and /hiddendata at boot but does not mount the partitions automatically. And on my twrp2.3 it makes directories /hidden and /hdata at boot.
But you could just have the script run umount on all those directories, then have it handle the making mountpoints and mounting itself.
And if your using my cwm or twrp then those will get backed up.as ext3 on stock and ext4 using cm9 making it easy to switch back and fourth.
After the update my PayPal app crashes, and sometimes the play store too..... I've done a clean install (full wipe).
The only problem I've noticed is the 3g and wifi signals stay Grey instead of turning blue.
Might be a bad flash/download. I would check the checksum and reflash.
You want to use the offline version, that link will offer a link to GoogleNow commands also. I would recommend installing the ROM, GoogleNow, and then GoogleApps
Folks,
Thanks for all the effort in creating this. I installed this on my MT phone but I keep getting 3G/Wireless signal issues/lack of connection. The only way to get a connection is by rebooting. I read through this thread and my understanding is that this issue is resolved.
Do you have any thoughts on what else to try to fix this?
Thanks,
Deepak
I have the same problem. I asked before but didn't get an answer for it either...
As far as a data loss that's resolved by a reboot, would toggling the data widget or cycling through airplane mode work?
Toggling through widget doesn't do anything, I haven't tried airplane mode. Still it's annoying to be having to reboot to fix data (that also includes calls, SMS/MMS - reboot for them to go in, pending to go out). What could be causing it?
Anyone have an idea why Google play music stops working as soon as I open it
Did you restore backups of any system or google apps after flashing the rom? I had some weird problems when i restored data for some of the google apps using titanium backup.
If you reflash the rom again, check whether you have the same issues right after you flash and before restoring anything else - or whether they only start after you start restoring your backups.
Just saw that VM has the Galaxy s2 now
