Whenever I put WiFi on in the 10/28 build, I believe it was, I got an mmc0 , mmc1, and mmc2 wakelock until I rebooted and turned off wifi. Has that been fixed?@last 2posts.... Something is way off, not wiped completely, app has gone rogue, etc. My battery runs a good 8 to 10 hrs on this rom, when on cm7 I think it ran 7 to 9 hrs. Thanks G60 and team!
Also Wi-Fi I leave on... always.
This seems to have resolved it. Thanks.Wonder if the kernel memory changes I imported from ics_chocolate are causing issues. If you would be willing to copy the boot.img from 11/12 and place it in 11/13 and try again I would appreciate it.
Over the last 2 updates, my maps has been acting up and crashing when I try to use it. Has anyone else had this issue, or is it just me?
It's not just you, I got the same results which I described in my earlier post here. I did some more investigating as follows:Just a heads up but when I flashed the 11/13 version then Google Now and finally gapps my Home key would give haptic feedback but not function properly. Re-flashed to the same results. Works fine without Google Now, and Now worked perfectly with voice etc. has anyone else had this issue or might I just have a bad .zip?
I love the ROM!! I have been running it for quite a while now and its super smooth. Only problems I have ran in to is the ringtone selection in some 3rd party apps will freeze the phone. Someone said it wasn't like that on the 12 build so maybe it is the kernel mem changes.
Other than that I wanted to point out the battery usage stats don't work. And so far the ROM runs smooth for the most part. I have some freezing and apps not responding occasionally but its usually with like 10 tabs open on boat browser lol! I'm trying to dial in the lowmemkller settings to help keep mem free but not killed of apps to much!
Gotta say g60 you are making great things here!!
Agreed...awesome rom... same small issues here...better battery stats can't even pull logs for battery...any idea what may have caused this?battery stats are the only issue that bothers me in the least
I'm not quite sure whats causing the problem. I have full wipe/flashed about 3 times already. Is this a common thing or should I go ahead and flash back to stock so I can see if it's a hardware thing?
Does your wifi work on other ROMs? And have you checked the checksum of the file you downloaded? If you have a bad download, then you will have a bad flash. I know the ROM had to be rebooted before the wifi would work in earlier randitions. I think that may have been fixed at a point, though.
Phone call end: When I take phone away from my head the sensor does not pick this up, phone remains black. Clicking power will restore view. If phone call is long enough, screen will lock and unlock will not work. Only way out is to convince other party to hang up. Doses not work with a telemarketer, thus had to reboot phone to end call.
Blue Tooth: Will not pare with any device.
Notifications: Although notifications appear to be in full working order they seem to be not passing context over to other launched applications. Best example of this is SMS, as it shows a message came in but when choosing it, you get the SMS application, but it's normal start context. In CM7 it would display the message received directly.
Well restoring CM7 until next version of CM9 is out to bang on!
Keep up all the good work, it's almost ready for prime time!
g60 dont release anymore updates until you get the camera working, thanks
In the wise words of Cartman "What ever I'll do what I want!"
I get like 26-27 hours wifi on 42-48 hours wifi off...but I have a lot of tweaks
