jamesd1085
All can be found on sites for build.prop and init.d tweaks...found many of them scattered throughout different sites...and just added removed and added and removed...lol lots of trial and error... I can post my edited build.prop file but my init.d is comprised of several folders...I use set CPU for over/underclocking min 61mhz max1401 mhz profile screen off min 61mhz Max 652mhz Wi-Fi & data disabled unless using....undervolted min too 800 with incredicontrol
Here is my full build.prop ...I'm pretty sure all of these lines are known tweaks.
# begin build properties
# autogenerated by buildinfo.sh
ro.build.id=IMM76I
ro.build.display.id=cm_triumph-userdebug 4.0.4 IMM76L eng.g60madman.20121025.234930 test-keys
ro.build.version.incremental=20121025
ro.build.version.sdk=15
ro.build.version.codename=REL
ro.build.version.release=4.0.4
ro.build.date=Thu Oct 25 23:49:56 MDT 2012
ro.build.date.utc=1351230596
ro.build.type=user
ro.build.user=g60madman
ro.build.host=mtdev
ro.build.tags=release-keys
ro.product.model=WX435
ro.product.brand=Motorola
ro.product.name=triumph
ro.product.device=triumph
ro.product.board=triumph
ro.product.cpu.abi=armeabi-v7a
ro.product.cpu.abi2=armeabi
ro.product.manufacturer=Motorola
ro.product.locale.language=en
ro.product.locale.region=US
ro.wifi.channels=
ro.board.platform=msm7x30
# ro.build.product is obsolete; use ro.product.device
ro.build.product=triumph
# Do not try to parse ro.build.description or .fingerprint
ro.build.description=triumph-user 4.0.4 IMM76L 292727 release-keys
ro.build.fingerprint=motorola/motorola_triumph/triumph:4.0.4/IMM76L/292727:user/release-keys
ro.build.characteristics=default
ro.cm.device=triumph
# end build properties
# system.prop for triumph
ro.telephony.ril_class=LGEQualcommRIL
ro.telephony.ril_prl=61007
ro.telephony.no_icc=true
ro.ril.def.preferred.network=4
ro.telephony.default_network=4
rild.libpath=/system/lib/libril-qc-1.so
rild.libargs=-d /dev/smd0
persist.rild.nitz_plmn=
persist.rild.nitz_long_ons_0=
persist.rild.nitz_long_ons_1=
persist.rild.nitz_long_ons_2=
persist.rild.nitz_long_ons_3=
persist.rild.nitz_short_ons_0=
persist.rild.nitz_short_ons_1=
persist.rild.nitz_short_ons_2=
persist.rild.nitz_short_ons_3=
# DEVICE_PROVISIONED=1
ro.dev.dmm=1
# system props for the cne module
persist.cne.UseCne=false
persist.cne.bat.range.low.med=30
persist.cne.bat.range.med.high=60
persist.cne.loc.policy.op=/system/etc/OperatorPolicy.xml
persist.cne.loc.policy.user=/system/etc/UserPolicy.xml
persist.cne.bwbased.rat.sel=false
persist.cne.snsr.based.rat.mgt=false
persist.cne.bat.based.rat.mgt=false
persist.cne.rat.acq.time.out=30000
persist.cne.rat.acq.retry.tout=0
ro.cdma.home.operator.alpha=Virgin Mobile
gsm.operator.alpha=Virgin Mobile
gsm.operator.iso-country=us
gsm.operator.numeric=310053
ro.telephony.gsm.ecclist=110,112,119,911
ro.telephony.cdma.ecclist=110,112,119,911
ro.telephony.ecclist=08,000,110,112,118,119,911,999
ro.telephony.num.auto.hyphen=true
ro.telephony.gsm.spn.shortname=true
ro.cdma.home.operator.numeric=310053
wifi.interface=wlan0
wlan.driver.status=ok
wifi.supplicant_scan_interval=90
wifi.supplicant_no_update_ctrl=true
service.config.gsensor_cal=1
libcamera.orientation=0
libcamera.testmode.colorbar=0
service.config.wifi=0
wimax.interface=wm0
dev.pm.dyn_samplingrate=1
windowsmgr.max_events_per_sec=500
#system props for the MM modules
media.stagefright.enable-player=true
media.stagefright.enable-http=true
media.stagefright.enable-fma2dp=false
media.stagefright.enable-aac=true
media.stagefright.enable-qcp=true
lpa.decode=false
lpa.use-stagefright=true
ro.hdmi.enable=true
ro.use_data_netmgrd=true
ro.config.ehrpd=true
keyguard.no_require_sim=true
ro.cdma.voicemail.number=mine
ro.telephony.call_ring.delay=0
wifi.wapi=0
ro.tethering.kb_disconnect=1
#For USB mount
persist.sys.usb.config=mass_storage,adb
# USB tether fix
ro.ril.hsupa.category=6
#HW accel
debug.fb.rgb565=0
debug.composition.type=dyn
ro.sf.compbypass.enable=1
debug.enabletr=false
com.qc.hardware=true
com.qc.hdmi_out=true
ro.config.disable_hw_accel=false
# ADDITIONAL_BUILD_PROPERTIES
ro.vendor.extension_library=/system/lib/libqc-opt.so
ro.opengles.version=131072
dalvik.vm.execution-mode=int:jit
dalvik.vm.heapsize=72m
ro.sf.lcd_density=240
ro.compcache.default=0
ro.com.google.clientidbase=android-motorola
ro.com.google.clientidbase.yt=android-motorola
ro.com.google.clientidbase.am=android-motorola
ro.com.google.clientidbase.ms=android-motorola
ro.com.google.clientidbase.gmm=android-motorola
ro.telephony.ril.v3=datacall,signalstrength
ro.com.android.dateformat=MM-dd-yyyy
ro.rommanager.developerid=cyanogenmod
ro.url.legal=http://www.google.com/intl/%s/mobile/android/basic/phone-legal.html
ro.url.legal.android_privacy=http://www.google.com/intl/%s/mobile/android/basic/privacy.html
ro.com.android.wifi-watchlist=GoogleGuest
ro.setupwizard.enterprise_mode=1
ro.com.android.dataroaming=false
ro.cm.version=9-20121025
ro.modversion=9-20121025
ro.config.ringtone=CyanTone.ogg
ro.config.notification_sound=CyanMessage.ogg
ro.config.alarm_alert=CyanAlarm.ogg
dalvik.vm.lockprof.threshold=500
dalvik.vm.dexopt-flags=m=y
net.bt.name=Android
dalvik.vm.stack-trace-file=/data/anr/traces.txt
persist.sys.purgeable_assets=1
video.accelerate.hw=1
debug.performance.tuning=1
ro.config.nocheckin=1
pm.sleep_mode=1
ro.ril.disable.power.collapse=0
ro.kernel.android.checkjni=0
mot.proximity.delay=25
ro.lge.proximity.delay=25
ro.max.fling_velocity=16000
ro.min.fling_velocity=12000
ro.mot.eri.losalert.delay=1000
ro.ril.enable.amr.wideband=1
ro.config.hw_fast_dormancy=1
ro.config.hw_quickpoweron=true
echo "500" > /proc/sys/vm/dirty_expire_centisecs
echo "1000" > /proc/sys/vm/dirty_writeback_centisecs
These lines help with battery...I have these in my init.d folder as well as some others...I'm still working to perfect the rest of my init.d folder.
ro.build.id=IMM76I
ro.build.type=user
ro.build.host=mtdev
ro.wifi.channels=
ro.dev.dmm=1
wimax.interface=wm0
lpa.decode=false
ro.hdmi.enable=true
wifi.wapi=0
#For USB mount
# USB tether fix
#HW accel
debug.fb.rgb565=0
net.bt.name=Android
pm.sleep_mode=1
