g01851
Is anyone else having trouble getting this to work? I've wiped data, cache, and dalvik then installed CM9 (01-06-2013) and the proper gapps. When I reboot, it hangs at the boot logo. I've tried CWM 5.5.0.4 and even reverted back to 5.0.2.7, still hangs at boot logo. I checked the md5sum of the zip files on my sdcard, and they match whats on the download site. I can restore back to CM7 with no problems, but CM9 will not boot. I waited 20 minutes last night just in case it was taking a long time, still no luck. Any ideas?
UPDATE: I also just tried CWM 6.0.1.9, did a factory reset, cleared both caches, and have the same results. Stuck at the boot logo.
Try also formatting /sys under the mounts and storage menu before installing the ROM
