dsmryder
Android Expert
how to use it?? i not understand.
Don't feel too bad. If you don't know you probably to start somewhere else.
GUNDUL46,
These fixes are comprised on how to build the frameworks base from source code. Edowar has a github with the all the device files you will need for the x6
https://github.com/edowar
It's not going to be an easy task as you will need to download the code, edit it and then build it and I am not sure what all you will need from edowar's github to make it work. Also I am not sure the fixes I listed above will work on the x6 as I don't believe anything needed to be changed for the x6 to get data to work? Sadly I don't know enough about the x6, you maybe better off posting on XDA in the x6 forum area. Good Luck! :thumb:
okay thanks for an explanation, because I also wanted to be ported rom like you![]()
Glad you fixed it.I want to thank everyone for their assistance in helping me try to get CM9 installed. The issue I had where I would hang at the boot logo occured after I tried installing ANY ROM... unfortunately none of the offered advice worked to resolve the issue. This morning I decided to unroot (via mtdev-unroot rom) and reroot my phone and start from scratch... and it worked!! I am now able to install roms again and am happily running CM9!
Glad you fixed it.
I see a lot of people talking about rooting their triumphs, but I don't know why anyone would need to root it themselves if they are going to install a new ROM since you don't need to root it to install a custom recovery and flash a ROM, and all the ROMs come rooted, so why are some people taking the extra step to root their phones?
Glad you fixed it.
I was thinking about that yesterday too, installing cwm only requires you to put your phone in download mode.. so would there be any reason to root beforehand other than troubleshooting reasons?
Stop trying to use these different camera apps. The camera is not fully functional yet, just wait until it is. What do you people expect? Be happy with the little bit you have now the rest will come in due time.
For the past three weeks I've been searching for the HTC Evo 4g from Virgin Mobile to replace my Triumph. I'ts a great phone and i've never had any real problems except I was on Gingerbread and I wanted the better features of ICS or JB.
In walks MTDEV with a rom that has a working camera. I downloaded and installed it in an hour. Unfortunately the camera view is upside down and in wide screen.
I DON'T CARE!!! I have ICS on a Triumph and if you can do partial, you can do full. I really need the camera but i'm loving the rom, and I'll stick it out till you get the camera working.
THANKS so much. Saves me $150 for a new phone and $10 extra a month on a new the Virgin Mobile play. So $270 for the year.![]()
))) yes, yes, I've sent in what I can to help.
Thanks All !It's only needed for CM9 ROMs without the camera fix code.1-06 already has it so no need to flash it.12-31 has it as well.what exactly is the camera flash zip is it needed for the 1/6/13 update or...
Agent Smith: Why, Mr. Anderson? Why do you do it? Why get up? Why keep fighting? Do you believe you're fighting for something? For more than your survival? Can you tell me what it is? Do you even know? Is it freedom? Or truth? Perhaps peace? Yes? No? Could it be for love? Illusions, Mr. Anderson. Vagaries of perception. The temporary constructs of a feeble human intellect trying desperately to justify an existence that is without meaning or purpose. And all of them as artificial as the Matrix itself, although only a human mind could invent something as insipid as love. You must be able to see it, Mr. Anderson. You must know it by now. You can't win. It's pointless to keep fighting. Why, Mr. Anderson? Why? Why do you persist?
Neo: Because I know the camera is almost finished, I know the developers will bring it to me, I know this because....I've already seen it happen.
G60, I'm noticing a problem with this build, my SMS is acting strange. I can text and receive texts from my daughter(T-Mobile) but not my son (Virgin Mobile) he gets mine but I don't get his. Any idea why?, he doesn't have the problem sending to anyone else. He has sat right across from me, sent and I still didn't receive.
