OP>MTDEV ROM Browser link>Testers> download latest tester
And some apps, such as Browser, simply will not pull up a keyboard.
I'm using the 4-15, it appears. Should I update to 4-23? Would that help? Where would I find that, since it's not in the Browser thingie?![]()
New data point on the keyboard issue: Messaging does pull up the keyboard, Browser (and another app I use a lot) do not.
@Seanette
The "No more space" messages does not come from Apex, but from Trebuchet, the default launcher. Even though it is not default anymore, every time you install an app it still tries to add it to the main screen. Clear defaults on apex and go into trebuchet to see what I mean. I just deleted Trebuchet, it was taking up a lot of space in the /system partition.
Another rebuild (using the symlinked Gapps) seems to have pretty much sorted that out (for now). I do find it thinking a router I'm 10ft away from is out of range a little unnerving, but it somehow finds the router and connects after giving me the "out of range" thing.
I not only rebooted twice during rebuild (after wiping caches and Dalvik, and after flashing ROM and Gapps), but pulled the battery briefly in the course of each rebuild.
One minor question: how do I convince this ROM and Apex Launcher that I really don't need a shortcut on the home screen for every app I install? I'll do those myself, TYVM. I do get tired of the "no more space on this homescreen" message, even when there's all kinds of open real estate on the screen.
I'll probably just go ahead and nuke Trebuchet, then. I like Apex fine, so don't feel any great urge to put up with Trebuchet giving me nonsense.
DH is playing with the camera on my phone again and is muttering about rotation. I hope he'll show up in this thread with more info. He did just now say that turning off auto-rotation in the system settings yields results he considers good.
Do the latest versions have any changes with the GPS? I've been running 3/20 and it worked a few times, then took about 20 to get a lock, now Navigation will reboot the phone every time it is opened.
Who is DH? And the FFC is almost next on my list.
I'm running the 4/23 build and am noticing some wifi problems. First, it takes a year and a day to connect. Seemed fine with the previous build and even faster on Froyocream. Second, the wifi disconnects constantly.
A question, what is it updating prior to boot after I clear the dalvik cache in recovery? I'm clearing it because it seems to be the only way I can use the Showtime Anytime app without the phone rebooting when I launch it.
I'm trying to install some custom ringtones (in OGG format), and can't figure out where to put them in this ROM. They're currently on my SD card. OK, so I'm also having trouble getting Root Explorer to move more than one file at a time, but that's probably an IOHS issue.![]()
Another IOHS moment: can't figure out sorting contacts or assigning individual ringtones.
