There is no stand-alone contacts app, and when I go into contacts via the phone, it has a bad habit of starting to dial someone when I press to attempt to pull up an edit menu.
You can not edit the contact from the phone app. You can however select the little square to the left where it would show the picture for the contact and then touch the area where the pic and the name are, then it will take you to contacts. Contacts should also be the first icon to the left of the app drawer, on the home screen. Once there press the menu button and you should be able to find what you are looking for.I can't select a contact without it dialing, and long-press does nothing at all. I'm on CM9.
I'd removed that item (called People on my setup) from the dock, thinking I wasn't going to need it much. It's back in there now, my husband has his own ringtone assigned, and all seems well.
This ROM does seem to do quite well for battery life compared to CM7, and performance is fine, so I'm happy as long as DH doesn't try to use the front camera again.
Odd note: when I was setting that ringtone, here came the cat very urgently wanting to be cuddled. She does that when I'm setting ringtones or using the speaker cleaner app. For some reason, sound emitting from my phone seems to flip the "affection" switch in her furry little head.![]()
Yeah, the Princess is pretty adorable, and she's very good at using adorable to get what she wants from her humans.![]()
I just flashed your newest build of your ROM, and I'm really worried, because I have no radio whatsoever.
Thanks dsmryder et al. for this! This is my first time installing a new ROM on my MT and I am loving it.
One little comment: what about including a warning that 20130218 has the no service problem in the OP? For a noob like me it seemed like this was the build I should use, and I was pretty bummed when my shiny new OS didn't get service. I finally found the anser on page 30-something of the thread, and am now running the 20130415 tester build, but it woulda been even better if I had known and just installed that version from the start.
Thanks again, I am loving my "new phone"!
Did you use one of the recent tester builds? I had this issue with the 20130218 build, but everything is fine with the 20130415 tester. Good luck!
Has the link for the 4-15 build been moved to the front page?
EDIT: Nevermind, I found the directory on you download site.
Sorry about the screams, everyone. My phone very suddenly threw "Encryption Unsuccessful" at me (see this post for a screenshot. I didn't post this, but it matches my screen). Wiping Dalvik doesn't happen. Even wiping and re-ROMing hasn't helped. About to try reverting to Gingerbread, using MT-DEV CM7.
Update: CM7 installed, and wiping Dalvik became an option again. We're now trying reinstall of CM9.
Update II: So far, CM9 is behaving, but it's only been about seven hours or so, most of it spent re-syncing music, books, and such. I'll keep you updated.![]()
Thank you MTDEV! I've been using CM7, and would like to update to CM9.
My problem is that when I install the ROM My phone won't continue past "Tap Android to Continue".
Actually, nothing works for me at that start up screen. The "emergency dial", and the "change language" button don't work either.
Is anyone else experiencing this problem, or know what I might be doing wrong? It seems this ROM is working for other users.
-Back up
-Wiped cache
-factory reset
-installed ROM
-installed GAPPS
Thank you for your help in advance!
Are you using the latest tester? Don't use the one listed in the OP. I haven't been able to mess with the FTP for a while. When I do I'll fix the OP and stop the confusion.
Used the tester. "Unfortunately setup wizard has stopped"
I don't know if your problem could be related at all to my text messaging problem. On Friday last week I stated to receive multiples of texts that were sent to me from my wife. I am still receiving texts from her that she sent to me on Fri, Sat, ect... while new messages both sent and received are a crap shoot if they go through or not. Very frustrating.well I had made a post before about me getting free 3g. Well it had worked on both cm7 and cm9(what im now using) and just last week it finally stopped working and now everytime I turn the data on my bars go from 3 all the way to an x for no service and it keeps doing that bouncing up to 3 down to x and I also want to go on to say that everytime i tick data on and my screen powers off, i hit the power button but nothing shows up so I always have to do a battery pull and completely disable the data.
Any suggestions of what the problem could pertain too?
I also tried factory resetting on a plain slate and going back down to cm7 and the same problem persists.
